Looking for info, research or discussions on reflected or deflected propwash
yankeeclipper
Jun 1, 2009
47
Northeast.
Does anyone know of any experimentation done with some sort of propwash corrector or deflector that would function like a contra rotating prop system? If effective, it would sure be lighter and simpler than one. To clarify, I'm imagining something like the "settling chamber" in a wind tunnel.
orion
Mar 2, 2003
5,800
Western Washington
What's your application? Are you talking about accounting for the "P" factor that's encountered during climb (and a bit during cruise) or are you talking about the issue of prop swirl?
8,962
It could be done, but I suspect it would create more drag than ailerons (for torque effect) or rudder (for P-factor) as ailerons and rudder have much more leverage than vanes close behind the prop.
I was considering something like that for a PPG, to counteract torque and possibly even act as weightshift steering... but the required surface size would be too unwieldy.
-Dana
"Calvin, we will not have an anatomically correct snowman!"
yankeeclipper
Jun 1, 2009
47
Northeast.
Well, there's the loss of streamwise thrust (to lateral or spiral thrust), and there's also the p-factor which I imagine must be a nuisance (or maybe not). As I've read, these were the targets of contra-rotating props--essentially an alley-oop of thrust. But I wasn't aware (per Dana) that the required surface would be large enough as to significantly diminish any gains in thrust with drag losses.
Latest posts
