The normal electronic ignition system most of us use (GPASC) has a hall effect ignition module that operates two dual-fire coils timed 180 degrees apart. The coils have 3 ohms of primary resistance. My project engine has this fixed-timing secondary ignition in conjunction with a Slick magneto. Now I am just brainstorming here... If I wanted to use the single secondary ignition module to fire all 8 spark plugs and leave the big heavy magneto home, could I replace my two coils with four 1.5 ohm dual-spark coils? I realize that I would need to develop a means of advancing and retarding the timing on the module. The question here is: Would the ignition module handle the job and would the coils function properly when paired in series (two coils for the back cylinders and two coils for the front cylinders)? I don't really need a lecture on why I should not give up the magneto and I do realize that the ignition module would be a single point of failure. I'm just looking for someone who really understands electronic ignition systems. Can I run two 1.5 ohm coils in series with an ignition module designed for 3 ohm coils? Is there any degradation in performance or reliability?
