K-Rigg
Attaches to any BurnTable CNC Plasma Table. Allows the use of table with out interfering with flat plate cutting. It is installed in a way that it allows the use of the length of the table. (On a 5x10 table, you can chuck up a 10' long piece of tube and cut the notch the end!)
3 jaw Self-Centering Chucks; Diameter: 6 (Inch); Jaw Type: Two Piece Hardened Reversible Jaws; Thru Hole Size: 1.570.
