N8053H
From my understanding the baffling on a VW engine and maybe others is of a pressured type. Meaning you want to trap the air with as little pressure lose as posible. Should one draw fresh air or cooling air for things like the mags and gascolater or whatever from the baffling. Should this air be drawn from the back of the baffling? My baffling has three 1 inch bungs coming off it or what ever these male things are called you hook sceet or scat too. Two cool the mag and one feeds air to the gascolator. IMHO I have a couple ways to deal with this. I thought about installing another male bung on the inside baffling. Then installing a bung in my cowl. Connect these with a piece or Sceet or Scat. Or I could remove these putting a plate over the hole in the baffling. Install the bung in the cowl and run sceet to the parts I want cooled.
But in my mind this needs to be changed. I have a three inch hole in my baffling the way it is setup.
Tony
P.S. I did order a book from Great planes on this subject of baffling a VW engine. I still wanted to ask here how you would deal with this. I wanted to share what I was thinking. Maybe I should do nothing.
Tony
