B & C spline-driven exp. alternator
Discussion in 'Firewall Forward / Props / Fuel system' started by BJC, Apr 11, 2019.
  1. Apr 11, 2019 #1
    8,877
    5,729
  2. Apr 11, 2019 #2
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,286
    3,029
    Mojave, Ca
    I have a little 20 amp backup unit on the RV-8. Never been used in anger, but it always works when I do the ops check. Other than that, not much to report.
    That said, there are some on VAF who are running them as primary alternators in an attempt to shed the weight and complexity of the belt driven unit. Have not heard anything but positives. A search over there will bring up more info.
    BJC likes this.
  3. Apr 11, 2019 #3
    5,750
    4,620
    Bill Bainbridge (the B in B and C) is absolutely first class. I had the privilege of having my booth next to his at Oshkosh one year, and I watched for a whole week how he deals with customers, and I heard what he said before and after customers came to visit his booth. I will definitely be happy to do business with him, and I believe he is a very highly qualified person to give you real-world answers. Sorry I have no experience or knowledge about the specific product, application, etc.
    BJC likes this.
  4. Apr 12, 2019 #4
    Lucrum
    Lucrum
    Lucrum
    Jun 10, 2008
    955
    188
    Canton, GA
    I own a B&C 28v spline driven alternator. It's mounted on an accessory drive pad of my GE T-58-8B. I had an adapter spline 3D printed using a material similar to what the alternator spline is made of. And I also had to fabricate an adapter plate. I have not however run the engine yet.
    BJC likes this.
  5. Apr 13, 2019 #5
    bifft
    bifft
    bifft
    Apr 17, 2011
    205
    75
    Utah
    Have the SD-8 8-amp one in my RV. Also have thier "crowbar" overvoltage module. Was easy to install, has given me zero problems (once I had the overvoltage wired correctly).
    BJC likes this.
  6. Apr 13, 2019 #6
    HomeBuilt101
    HomeBuilt101
    HomeBuilt101
    Oct 20, 2015
    250
    15
    Aguila AZ
    >What are the pros and cons for the spline-driven verses the belt driven?
    Finally I get a chance to give back to the community and assist someone!!!
    I have a SD-20 (spline driven B&C 20 amp) on a Lycoming IO-540 and I am very happy with it. I have two independent electrical buses and the SD-20 powers the smaller bus while the SD-60 (belt driven B&C 60 amp) powers the big bus through the multi-color magic of EFIS I always see the two electrical systems operating side by side on the Dynon.
    The SD-60 has the benefit of being belt driven so the large flywheel pulley spins around and then the mechanical advantage spins the SD-60 pulley really fast even at idle so the SD-60 can produce its full rated power at low engine RPM.
    The SD-20 does not have the mechanical advantage of the belt drive so at idle it has limited production.
    On a real world example:
    The post start idle (1000 RPM) the SD-20 is only producing 12.1 volts on a 8 amp load whereas the SD-60 is producing 14.2 volts on a 23 amp load. Both sides have a battery that was bus tied during the start then isolated for all other operations so each alternator is recharging its respective battery and powering its respective bus (the SD-20 has a small electrical system and the SD-60 has a much bigger electrical system).
    Then during the engine run up at 1700 RPM run up the SD-20 is spinning fast enough to now produce 13.7 volts on a 8 amp load and the SD-60 is producing 14.3 volts on a 18 amp load.
    Later during cruise flight the SD-20 is now producing 14.0 volts on a 6 amp load whereas the SD-60 is at 14.4 volts on an 18 amp load.
    SO the SD-20 is not spinning very fast at idle so it just matters what you want to use it for...a small electrical system it would be fine.
    The customer support of B&C is OUTSTANDING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    gtae07 and BJC like this.
  7. Apr 13, 2019 #7
    Oct 19, 2003
    5,627
    2,866
    So, how many hours do you have on the system? Sounds like Bob Nuckoll's Z-14 dual alternator/dual battery/crossfeed design. True?
  8. Apr 13, 2019 #8
    HomeBuilt101
    HomeBuilt101
    HomeBuilt101
    Oct 20, 2015
    250
    15
    Aguila AZ
    Just built the system and only have a few hours of flight time on it. It is essentially to electrical systems with a bus tie. The left system powers the left side screen, taxi light, one radio, and the other system powers all of the same stuff listed above plus everything else on the airplane
    wsimpso1 likes this.
  9. Apr 13, 2019 #9
    8,877
    5,729
    Thanks HB01. That is helpful.
