American GEM - Youth Flight training System (from Lithuanian Youth Glider)
DBN
Mar 25, 2021
18
Indianapolis, IN
The American GEM - Youth Flight Training System consists of: American GEM Ground Effect Machine ( hence GEM) glider, a Plane on a Post [PoP] Stationary trainer rig, powered ground tow line loop, ground school - and sortie by sortie flight plan for students, all of which fit easily into an 8'X8'X22' standard enclosed trailer. We are based in Indianapolis IN. There is a FaceBook page American GEM will get you there.
Currently have two GEM's, prototype is a modified Kolb Firefly - 22' wingspan, with safety cage, PoP fitting, and Glider Tow release. Gear is modified to be nearly "flat" for initial training. GEM #2 has FireStar wings (27'- w/ under camber) and has flown at less than 25 mph.
GEM #1 has been used extensively with youth 11-16 (and some adults! it is FUN) for PoP training and low and high speed taxi training. It "hops" at about 25-27 mph.
Next step is the Ground Tow Line power system - fabrication is underway now!
We start tow testing and verification of the taxi portion of the Instructors and Students curricula next week.
Video is of GEM #1 (still wearing some leading edge flagging for attention at an event - will not do that again!) as we did an assembly / disassembly check list confirmation.
Intent is to get to a full package that we will provide INFORMATION on to others wanting to duplicate the Lithuanian LAK-16 based ground tow line flight training system.
If you are in the Central Indiana area and want to help PLEASE contact us via the FB page.Screen Shot 2021-05-01 at 5.38.06 PM.pngScreen Shot 2021-05-01 at 5.38.35 PM.pngScreen Shot 2021-05-01 at 5.39.09 PM.png
DBN
Mar 25, 2021
18
Indianapolis, IN
The first step for youth in learning to aviate is to understand the interaction of moving air and the aircraft controls. Our American GEM PoP (Plane on a Post) helps get that understanding before actual taxi, hopping and grass skimming. (GEM = Ground Effect Machine)
The series of photos show how the AmGEM PoP gets assembled onto the airframe.
This is a great project for an EAA chapter to make and use at Young Eagle events - where the youth are waiting for their flights.
Video is in a 10 knot breeze - freely turning in all axis.
each photo has notes to help explain the process.
We are in Central Indiana. Give us a response if interested in seeing this system at work!CE8D2FE1-782C-4644-9777-C877E1969F6D.jpegFF4C477B-4C29-411E-A048-5C57CE2A92FE.jpegC92A966F-348A-4453-9F6F-8B37402A2132.jpeg9E665039-FB2B-4C06-A183-0B76247BAD0C.jpeg96A65264-F071-473E-AB2C-64ADD9020387.jpegCF50BD68-63DC-4858-B5B3-74786AF57A95.jpeg
EzyBuildWing
Sep 23, 2009
315
Sydney NSW Australia
Great idea with the Glider......
Be sure to suggest all aspiring "Young Eagles" watch the inspirational Movie below.....it's all about a young girl who is determined to learn how to fly.....stars Bette Davis......watched it so many times, it's brilliant!
DBN
Mar 25, 2021
18
Indianapolis, IN
The American GEM (Ground Effect Machine) version 2 [GEM II] has completed a rigorous series of taxi tests and ground skimming tests on hard surface and grass runway. We have a few minor improvements to make - padding on some cockpit rails, seat harness arrangement, and maybe longer gear or larger wheel / tires.
GEM II with 1/2 Flaperon gets her tail up at 20 MPH, hops at 23-25, and lifts off in Ground Effect at 25-27. Likes to fly at 30 - loves it at 35.
Photos of GEM II testing -
Sunset photo at end of day
Tail up - high speed taxi
Grass Skimming - two images
Full flight - Video
Our goal is to deliver a package of information - "The Book" - so that any youth oriented flight program can duplicate this program - more on that later.
"Stick in the hand
Wind in her hair
Smile on his face
Eyes on their futures!"
D_limiter
Jul 13, 2018
139
Norcal
Would love to get something started like that here in NorCal! Thanks for all the work you are doing!
karmarepair
Jan 13, 2011
575
United States
If starting from scratch, a Harper Motorglider 101 might be a good Plane On A Pole, although it might need a little more wing.
Making it could be a Young Eagles project.
Cloudster would be another candidate, but you'd need a chunk of lead in the nose to balance it.
The nice thing about starting with a Kolb is the folding wings/tails. Start with a Ultrastar?
DBN
Mar 25, 2021
18
Indianapolis, IN
And hers is our
Any of the Kolb fleet would probably work well - having the strong top-of-frame tube is the key to mounting the trailer hitch type ball joint.
76E76891-7539-4801-B1F5-2BBA29928293.jpeg76E76891-7539-4801-B1F5-2BBA29928293.jpeg3A870530-3D4A-4775-888D-49294DC65FA1.jpegA0114512-2388-4189-91B5-076E870ACD1F.jpeg8304AFD6-7E68-4ACD-A971-AD63D7A60B0F.jpeg
DBN
Mar 25, 2021
18
Indianapolis, IN
And here is our American GEM video - high speed taxi, hopping, grass skimming, and then with a glider pilot - as the file size for the video is too large - PLEASE peek at our American GEM page on FaceBook. (Still have to learn how to use this forum system)
karmarepair
Jan 13, 2011
575
United States
Hoppin on the runway with a quad tow.
Not sure this will work for everybody, but link to the Facebook video of the progression
DBN
Mar 25, 2021
18
Indianapolis, IN
What is the white painted fitting the hitch ball is bearing on?
Part Number 1808010 Goose Neck Coupler Head - This is then built into a 2X8 8"square with a hole in the middle for the "dome" and a piece of 3" heavy Wall PVC that is carved to fit the upper tube of the KOLB. (I need to make a drawing of this!) 1" wide soft steel straps are shaped to fit the installation - going from the top of the wood then over the upper tube and back to the wood. 1/2" -20 bolts clamp the whole assembly together.
karmarepair
Jan 13, 2011
575
United States
Thanks! This Buyers coupling head looks a little handier to adapt than the competing Bulldog units, which lack the "sandwich" design for the retainer, and thus lack handy holes. It's also substantially cheaper https://www.amazon.com/Buyers-Products-1808010-Gooseneck-Coupler/dp/B01CIO6BD0 Ignore the description on Amazon, it's for a different Buyers product.
Do you ballast the cockpit for lighter pilots to get the Plane On A Pole to balance with wee pilots?
  • Like
Reactions: DBN
DBN
Mar 25, 2021
18
Indianapolis, IN
Thanks! This Buyers coupling head looks a little handier to adapt than the competing Bulldog units, which lack the "sandwich" design for the retainer, and thus lack handy holes. It's also substantially cheaper Amazon.com: Buyers Products 1808010 Gooseneck Coupler : Automotive Ignore the description on Amazon, it's for a different Buyers product.
Sorry for the delayed response. We have the American GEM balanced with about a 120 pound teenager. There area actually weights attached to the tail wheel unit to do this! Then we have a 10 pound "saddle bag" that slides along the boom to final adjust for heavier pilots. Can be seen in some photos.
