1/2 VW plans
mullacharjak
Nov 5, 2010
204
Peshawar Pakistan
IMO the Le Pelican has enough wing span 37 feet to carry the weight of a 1600cc VW engine unless one wants to fly without a licence.The Australian tyro is a smaller wing but flies with the 1600cc.Fisher super koala flies fine with a 1600cc(example in Finland).The 1600cc is a very under utilized engine.Maybe because its avaiable and too easy to convert and its considered to be very heavy.
F3A-1
Jun 9, 2009
26
Princeton MN USA
Does anyone have a "full case" with rear mag? I have not found one yet. If plans exist I would like to buy a set.
I have an engine with the distributor and want to convert to rear mag or half case with rear mag as a last resort.
Thanks,
Lex
JohnB
Aug 18, 2019
94
Thanks,
Lex
Scott Casler will build you a full case with mag but I doubt he will provide plans. One of the Legal Eagle drivers is a mechanical genius and has converted several in that configuration, I think he posted some napkin drawings sometime back, I'll check.
He also developed a spin on filter adapter that uses a Goldwing motorcycle filter and sits where the oil cooler was.
JohnB
15,346
Rear mag should not be much issue because they have been done to full VWs since the 60s. The Teenie Too plans came with very basic engine conversion documents.
F3A-1
Jun 9, 2009
26
Princeton MN USA
Well, my full case, 1/2 VW has the crank cut in half.
I have a couple of other full case, full cranks such as a Revmaster with the mag driven from the aft of the crank.
I can create an extension, but was just looking to see if it had been done before with the 1/2 crank.
Thanks for the lead JohnB
TreeTopPilot
Aug 8, 2011
26
Eastern US...for now
The 45 hp half vdub I have runs fine. Baught parts from Scott and built from there. 32 hours on it. Pulls a 56 x 24 performance propellors prop 172 lds static pull @ 3150 rpms. Dual 26 mm mikunis.
sotaro
Feb 26, 2011
181
San Francisco
Radford,
were you able to bolt the case to the firewall? No starter, no alternator, just a magneto? Any pictures? It would seem that the full case would be easier in that other than clearancing the front half of the case, the rest of the work on the case would be blocking off the holes.
Twodeaddogs
Jan 18, 2009
1,155
Thanks,
Lex
Look up the old Peacock conversion, which featured a chain driven Lucas SR 4 magneto. British origin.
Turd Ferguson
Mar 13, 2008
5,713
Upper midwest in a house
So who sells the best 1/2 VW cut case plans?
Dave Carr may have been the first person to make a 1/2 VW in ~1974. He was the first person to draw up plans using cut and full case. Whether you use them or not, the plans are very clear an concise on what needs to be done. Great Plains sells reprints of Dave Carr's plans.
I sold a set of original Dave Carr plans a few yrs ago so they are still out there.
flitzerpilot
Apr 19, 2017
176
The prototype Z-1 flew well with a 1600cc VW for pilots weighing around 170 lbs. and the weight of the engine allowed a short nose with the pilot having a good cockpit view, ie. not seated forward between the wings as such, which would inhibit view. However the performance was transformed with 1834cc.
