Wire type?
SteveR
Jan 11, 2005
37
Norman, OK
I'm in the process of installing a radio, intercom, and battery. What wire types do people commonly use? MIL-W-22759/16? This is in an open cockpit aircraft, and wiring will be minimal, so I'm not concerned with toxic smoke/fumes (If my airplane is on fire, I've got more immediate problems...like the wings disappearing). I would just order some wire from Aircraft Spruce, but I have no idea what the sheath is like. I'd like something with a really tough, harder sheath, not the softer sheath that standard hook-up wire has.
Also, does anyone make or use wire with a braided sheath anymore? I think this would look better in my plane. I've seen some that seem to be a plastic sheath with a cloth braid. What is the general consensus on the durability & quality of this wire type, and is it even available today?
wally
Mar 31, 2004
928
southwest TN.
This is a topic I do know a little about from my previous day job. Gulfstream Aerospace, engineering, 16 years.
yes the MIL-W-22759/16 is the standard airframe wire. Aircraft Spruce sells it by the foot. I think it has a clear nylon outer layer and should do just fine anywhere in the airplane. Get a copy of FAA advisory circular AC43.13-1B, it shows how to install wiring among a lot of ohter usefull info. It is available free on-line at the FAA.gov website.
If you are concerned about it being rubbed against in your cockpit, you can put the wires in a bundle and then run the bundle through some plastic tubing. Or add some polyolefin shrink tubing over the wire or wires to help protect them.
Some of the older planes I have been around had the outer cover as a cloth braid. It was that way because the insulation material was not as durable as it is today.
I too am building an open cockpit plane (Pitts) and almost all the wiring will be in front of you behind the instrument panel so it should not be a worry.
And keep in mind, whatever you use, there will eventually be a time you have to show the plane to the FAA inspector or a DAR (designated airworthiness represenitive) in order to get your airworthiness. He will be much happier if he sees aircraft type materials and construction!
Best wishes,
Wally
edited to add:
Oh, I just checked your web pages. Nice plane and it is already flying! The only problem you might have is finding places to put the radios.
I am saving my pennies for a Micro-Air 760 comm and the T2000 transponder. They are about the only things I can fit in my little one place Pitts. I have a Val-Com 760 radio in my Cessna 150 and really like it but it is just too large to fit in the Pitts. Good luck!
SteveR
Jan 11, 2005
37
Norman, OK
Thanks Wally, that tells me what I needed to know about the wire. One more question...do you (or most people) typically color-code the wires in your planes? The engineer in me wants to color code every wire, but aesthetically I think one color would be much better. I do have labels for each end of the wires.
For now I'm going to mount the antenna on the belly...the only place I have a suitable ground plane. I'd like the antenna to be completely hidden, so in the future, I'm going to try to mount a dipole antenna in the rear of the plane, since it is wood I think I can pull it off. I just need to find a location where I can mount it and maintain the proper spacing from the control wires, and do all of this through the inspection covers. Its kind of like trying to build a ship in a bottle. :D
I had every intention of using the 760 Comm radio when I bought this plane, but the A & P who did my pre-buy talked me into a handheld (for around $700 less than the 760). I have a VXA-150, so far it works fair with the rubber ducky antenna. Believe it or not, I have actually had a conversation at a 40SM range with a buddy in his Citabria. I think that was a fluke, I was probably benefiting somehow from the position of the handheld that day. My plane is based at a class D field UNDER DFW class B, and the tower's only complaint is wind noise.
HOWEVER, using a handheld only a few inches away from my intercom causes an awful squeal when I transmit. That is why I am hurrying to install the belly antenna, and I'll do the internal antenna when I have more time to figure it out.
I also initially had plans to use the T2000, but right now I'm not having any issues under the class B DFW shelf, and I don't want to pay $2,000 for the occasional trip through the class B.
Thanks again for the tips!
Craig
Jan 30, 2003
543
Jupiter, Florida
Wire color
Steve -
I did my Duce wiring using only white (well, OK, the battery pos. is RED), and even with both ends of each wire coded, it is a major PAIN IN THE TAIL to sort them out when working out problems.
A trip to the local avionics shop revealed a rack full of 20 and 22 ga. colored wire - probably about 12 colors of each size, and also some colored shielded wire.
Do yourself a big favor, visit an avionics shop and get some wire from them - it makes tracing the circuits a breeze.
I am using hte MicroAir, and really love it. Also have a hand-held, but in the open-cockpit, it is hard to hear. Does have good range, however, and is great to leave with my buddy while I am test flying - we usually use 123.450 to talk back and forth while doing the time to climb, etc.
SteveR
Jan 11, 2005
37
Norman, OK
Good suggestion Craig, I will have to find an avionics shop. Its a pain to order all of this stuff online anyway.
Were you using a headset with your handheld? An adapter came with mine. I also bought some leather mic covers ($12), and they make a massive difference in the useability of the intercom.
