Warp drive 72" 2 blade Left hand prop,HP hub, new, unused, in box, can be shortened, drilled for SAE1 hub (6 holes on 4" diam circle) and Rotax 75mm diam circle. Can be used on Subaru direct drive pusher or Rotax 2 stroke tractor. $450
Other engine parts can be seen on "Air Command EA81...." thread posted today
Also available prop hub 7075-T6 for subaru EA-81 direct drive with SAE1 hub pattern $90
Call 904 6102530, located St Johns, Fl
