Turbine power for self launch and sustained flight.
Swampyankee
Dec 25, 2015
1,441
Earth USA East Coast
That would be neat but all the ones I've seen had centrifugal compressors. Can you do a bypass duct with a centrifugal compressor? On another note I've seen a little 7hp turboprop
Yes. Look at most of the small turbofans. I think everyone but Wiiliams designs there small fans around a turboshaft core, and most small turboshafts havecat least a centrifugal stage.
Swampyankee
Dec 25, 2015
1,441
There was a UK company displaying a TF engine they were developing at Oshkosh in 2004. The centrifugal engine without the geared fan was probably in the 40lb thrust range. They were talking 2-400 lb thrust with the fan. I tried to contact them without success a few month later for a follow up. I'm sure the gear box was the deal breaker or we'd see them all over the place. Reducing that kind of rpm to a 20" fans useable level with reliability would be a project worth doing but certainly not easy.
A turbofan with 400 lbf thrust from core producing 40 lbf of thrust seems awefully optimistic. As for the gearing, a fan from the turbofan is likely to have a tip speed of around 1200 to 1500 fps, so 14,000 to 18,000 rpm. At at guess, the compressor would be spinning at about 100,000 rpm. You could try an aft-fan. It worked, more or less, for GE.....
clanon
Jun 6, 2007
1,105
Last item is the airfoil change, the HP-18 has a FX-67 from the seventies, I am modifying the gemetry to the Udo 15.3 . This is a unique airfoil developed by Udo Rumph who has built two HP-18's . This airfoil has been proven by Udo and has an improved climb and cruise polar compared to the FX-67. Udo is known to be competitive in the 15 meter class while competing against some of the 150K glass ships.​
Chris[/LEFT]
http://www.soaridaho.com/Schreder/HP-18/SUPER_HP_18.html
PS: I would say : he seems to be "Ribletting the Worthmann"...
