GuinnessGuy74
I have a question regarding foam cores in a composite sandwich. If you micro/flox/5-min epoxy two pieces of foam and then glass over it, how much strength do you lose over a single piece. What about joining 3 pieces, etc (see pic for an explaination) ?
The reason I am asking is, I was wondeirng if you can use pieces of foam instead of single sheets. Just to try and utilize as much foam as you can and eliminate waste...
Thanks,
Jim
Thanks,
Jim
