Raptor Composite Aircraft
7,376
FB report — no leaks with latest design.
Best,
Tom
And no breather for that casing. It has oil going in, a drain and currently no leaks. Anyone else see an issue there?
Ross, Peter said in a recent-ish video that he didn't calculate that 1800lb as he didn't know how to get solidworks to do it back then. He just looked at similar aircraft for an idea.
Venom
Jun 26, 2016
58
Pacific NW
I think that ballast will stay there given the massive weight of the propulsion package. He doesn't have an idea of where the C of G is anymore but almost all weight has gone in aft.
in 2013, the empty weight estimate was 1800 pounds, it's now likely more than 3200... Huge miscalculation and weight growth.
Unfortunately none of us know what the thing weighs now nor where the CG is. But if he is talking to the DAR then I would bet that he knows exactly what it weighs and where the CG is. And I would guess that you are correct. With more weight going way aft and Jeff building a specific chamber for ballast up front, either the ballast stays or the battery gets jockeyed.
On a different note....Peter indicated that he was going to run a tied down static thrust test. If i understood correctly this test on a propeller driven airplane is of nearly no value. Is that not true?
10,806
Such a test can be useful for setting the high RPM stops in the propeller.
rv6ejguy
Jun 26, 2012
3,749
Calgary, Alberta, Canada
It seems very odd that Peter hasn't showed the weight now on a new vid since he shows everything else. With the DAR inspection imminent, he'll have to have that information. Peter's been repeatedly asked to reveal the new weight in the YT comments for months now with no response.
Any time spent running the engine at high power on the ground will be useful to uncover potential issues. The thrust test will make for a good video too- a little more interesting than putting sun visors in...
Grumpy Cynic
6,906
Is that kind of like the inverse of the law of diminishing returns? "Well it's already 1400 pounds over weight. What is another couple of pounds from the sun visors going to make? After all that is only 0.14% of the problem."
7,376
It needs weight forward. Those sun visors and ridiculous honeycomb pedals aren't as big a penalty they seem. Not as efficient as weight in the nose, but part way there. What he really needs to do is get weight out of the back.
flyboy2160
May 25, 2014
332
california, USA
After the elastomer damper fails again, I predict the IT Peter fix will be.........replacing the elastomer engine mounts with solid aluminum. Then maybe he'll add elastomer mounts between the engine mounting frame and the airframe. That'll fix it!
rv6ejguy
Jun 26, 2012
3,749
I am really surprised that his engineer friend Mark hasn't said something about this aspect of the PSRU design and the fact that the new coupling isn't rated for the rpms or torque of this engine. Does he know know all this? Has he told Peter but Peter doesn't listen?
FarmBoy
Mar 14, 2012
129
Gainesville, VA
For 4 cylinder engines, there is still the question of TV with the PSRU and I'd never try to get over 100hp/L out of an engine for aircraft use. Chances are that the long term durability wouldn't be there, especially at 150hp/L.
Yes, TV should be analyzed with any engine. A TV reduction coupling or dampener could potentially be required and would, of course, add a few pounds (though unlikely enough to offset size/weight reductions). Such a coupling may be desirable for even a V8 engine for both TV improvements and potential protection from a prop strike.
You are certainly correct that reliability/durability should be at the forefront, especially for aircraft bound items. While HP/L might be an interesting generalized value, there are certainly many engines with << 100HP/L with very poor reliability and likewise high reliability engines > 150HP/L. What matters most is the design of an engine and what its weak points are from a durability/reliability perspective. As with a diesel, higher HP per volume and/or per revolution makes the design of pistons, cylinders, valves, wrist pins, etc. more important. DeltaHawk found this out the hard way as at least one of these items (wrist pins) was the cause of premature failure requiring engine redesign. All of these items are designed for at least 350 HP in the 2.3L ford engine targeting automotive use and at least 100,000 mile service - this corresponds roughly to a 2-3,000 hour TBO. It also depends on what you mean by long-term - while durability between TBOs is unarguably paramount, a lower life-cycle cost engine that can meet its TBO is just as viable as a "more durable" engine depending on use case (and wallet).
FarmBoy
Mar 14, 2012
129
Gainesville, VA
Do you have the specs on the new lord coupling handy? I remember looking it up and finding it wasn't the one someone here referenced.
flyboy2160
May 25, 2014
332
california, USA
The videos look like their DynaFlex LCD, which are used for for truck trannies, etc. If so, it won't make a difference which one he picked: the dynamic alignment specs look pretty tight. I suspect these are intended for use between fixed components, not in the wobbly installation he's got.
(I designed one-in a long, long time ago at work, but I've completely forgotten everything....except that the parts were nominally fixed and that I needed the consultation with Lord engineering.)
Scheny
Feb 26, 2019
179
Vienna, Austria
It should be easy to locate Marc using the comments from the videos. Would be the easiest way to tell Marc what state of the arty for a prop drive looks like. Seems at least he has some influence on Peter.
I admit, the first iteration of the reduction gear in my boat failed too, but I got an expert and let him tell me what I did wrong.
7,376
LCD-0150 XR-A, rated at 150hp, 565Nm, 20lb
I'm trying to find out which turbos he used, anyone know?
7,376
I wonder how he is going to extricate himself from this mess.
He's using Marvel Mystery Oil to add lubricity to the Jet-A. Problem with that idea is, it doesn't...
TarDevil
Jun 29, 2010
490
Coastal North Carolina/USA
Some captains prefer to sink with their ship. Hope he is not one of them. But in case he prefers this way out, I hope the camera has 4K
What really scares me is the possibility he'll get desperate after Elliott refuses to fly it and let one of his YouTube enthusiast with some corporate flight time test fly it. He's had several offers, not sure how serious.
7,376
That or fly it himself is far more likely than Eliot flying it. That is assuming that it stays together long enough to reach TO speed.
Next episode will probably be the final, final, final housing rebuild to add the breather that he didn't know that it needs...
