dcstrng
I’ve been scouring the gallery and so far have not found someone’s close-up of what the stabilizer spar attachment looks like…
Maybe I’m making this too hard… it appears to me the stab-spar is simply welded under the top longerons (which are subsequently cut away) and supported on top by two 3/8ths tubing supports into the rudder post, and then below similarly (tied directly to the underside of the stab spar down to the lower longeron/rudder-post junction) as well as the 1/2†tubing that runs more or less from the same longeron/stab-spar junction to the junction of the lower longeron and the vertical…
I feel like I’m missing something – is that it? Guess I’m looking for some sort of bracketry that locally ties the stab spar to the top longerons beyond welding where the tubes cross more or less at 90-degrees…
If someone could point me to a close-up I’d appreciate it (or correct my presumptions above)
Thanks…
Thanks…
