My Zenith CH-650 B log book reference
anvegger
Jul 6, 2015
481
LACONIA NH USA
More or less I am satisfied with the look of that step
May be next step would be a little less stressful
But overall not bad in my personal opinion
anvegger
Jul 6, 2015
481
LACONIA NH USA
All right a bit of homework and video guidance this morning from HomeBuiltHelp.com. Spend a good hour working on understanding of Gus' approach to the Canopy Conversion. Some of his ideas are definitely a must. Starting from removing all installed tubing except the rear canopy support 65C3-10 and rear canopy frame 65C3-1. Also put together the forward top skin just good enough to make the visual frame available
The rear part of the canopy bubble has to be trimmed firmly to get inside of the baggage area
Drilled and clecoed the pilot side of the canopy to the frame
anvegger
Jul 6, 2015
481
LACONIA NH USA
The bubble overlays the cockpit and will be trimmed later at this moment we have to work on the positioning and securing the plexiglass over the frame
The big mistake that I made - was inserting the edge of the bubble under the welded steel tab - it was a good positioning point but created an extra tension
As a result - the bubble cracked while I was drilling the pilot hole for the frame
anvegger
Jul 6, 2015
481
LACONIA NH USA
TO stop exposure of that crack - I drilled the hole at the end and applied a few cure staples to hold two pieces together
Later used a few drilling points to secure the plex from expending
Have to find the way of how to recover that broken glass
anvegger
Jul 6, 2015
481
LACONIA NH USA
May be using the extended version of a side cover will help
All right use of the gentle technique definitely prevents that from the happenning
right now the time to take the measures and trim the bubble to get the edging done
Taking the bubble off for trimming
anvegger
Jul 6, 2015
481
LACONIA NH USA
I am using a Dremel tool for cutting the plexiglass
The good side is covered with 1/4" studding just for protection
And the trimming is accomplished
anvegger
Jul 6, 2015
481
LACONIA NH USA
Now is the time to install the bubble back on top and fix the missing holes
The broken side is also clecoed gently with all the cautions applied
Drilling and clecoeing on the pilots side is done
anvegger
Jul 6, 2015
481
LACONIA NH USA
Rear side of the canopy was installed without any issues
Smooth transition from the tube to the skin is available to share
The pilot's side drilling is much better and persist
Overall I am happy with today's results
anvegger
Jul 6, 2015
481
LACONIA NH USA
A couple of days ago we left clecoeing the bubble only to the rear tube. The bubble is trimmed and has nicely inserted into the fuselage. Now the time to cut that bubble gently in two pieces. Starting from taping the line - approx 10 mm from the clecoed central circle
The goal would be cut the bubble off of the rack
Put it on top of the wings box, firmly hold it and start cutting using the dremel metal disk
anvegger
Jul 6, 2015
481
LACONIA NH USA
Just in case of reducing the tension - used the small ladder underneath the third point
Ran the cut from center down , from bottom up on both sides
No pressure - just gently moving the disk up and down
The rear part of the bubble is off
anvegger
Jul 6, 2015
481
LACONIA NH USA
Time to install the front part back onto the frame
The rear tube with the support are removed to make the front part of the bubble easy managed
The front tubing is trimmed to get exactly lined up with the edge of a front part of the bubble
Time for clecoeing
anvegger
Jul 6, 2015
481
LACONIA NH USA
After that is completed and re-attached all the pieces - time to bring the remaining part of the bubble back on top
Make sure that everything is lined up
Not bad work - lots of trimming to go
anvegger
Jul 6, 2015
481
LACONIA NH USA
Victor and Daisy helped me a lot today
But we all worked hard on that project
Till new day - and drilling the remaining tubing
anvegger
Jul 6, 2015
481
LACONIA NH USA
One extra month since the latest update and some progress to report. The canopy is about 90% done and waiting only wrap to complete the siding
Here how was it done. Trimming the plex is essential
The side langerones are tricky when not connected to the skin
anvegger
Jul 6, 2015
481
LACONIA NH USA
The idea was to keep the shape as close to the bubble as possible without changing much of a skin
And finally I was able to rivet that part
Not bad came along finally and looks nice
anvegger
Jul 6, 2015
481
LACONIA NH USA
Of cause it took a lot of preparation and accurate trimming from all remaining parts
But over all I would say I am happy to see what is came up from that task
Thinking of polishing and using the plastic edge but that is later
anvegger
Jul 6, 2015
481
LACONIA NH USA
At this time I need to come up with empinnage tuning and installation. But becase it was assembled one year ago and I used cortec it bonded firmly into the skin. Using hinge threat to get removed did not help
And the installation was not possible in an assembly collected.
So I started the disassembling the one year old assembly
Firstly - removed all the rivets from the hinge on the firm set side of the stab
anvegger
Jul 6, 2015
481
LACONIA NH USA
Then used the pin and the stainless ruler to unbound the hinge. But the biggest help came up when I applied a lot of paint remover
After may be two hours of a battle - I was able to rescue my stab
And after that - the leveling process started
anvegger
Jul 6, 2015
481
LACONIA NH USA
Used the laser pointer to find the exact position of my stabilizer - horizontal part
All across the plane - leveled every single corner
And overall I would say it is succeeded
