wbpace
Last weekend I was not up to working in the shop, so I drafted my design for toe brakes. I came across some plans for the brake pedal for the Acro II, adapted it to work with the Sonerai rudder pedals, and drew it all up in SolidWorks. That allowed me to fully model it, independently simulate motion of the rudder and brake pedals, check for interference between parts, and generally make sure it would all work. I’ve attached a picture. It is based upon the Matco MC-5 master cylinder (I scored two at a good price from Wicks).
Basically it is the standard S-II aft rudder pedal with the top tube (that makes up the adjustable part of the pedal) turned sideways to make a pivot for the brake. The height of that tube stays the same at 7-3/4 inches, and the brake pedal adds another 2-1/2 inches. This gives the 2.5:1 mechanical advantage that Matco says is needed on the cylinder piston. Spanning across the fuselage, the position of the pedal is at exactly the same place, with the same width of the part that touches your foot, so clearance with any front seat occupant will be the same.
Rudder pedal adjustment will be done where the cable assembly attaches to the pedal horn. The three-hole strap assembly that is specified in the plans is replaced by one with multiple horn attachment holes that will allow fairly easy adjustment.
My only problem is I cannot find any references for designing with 4130 tubes, so I am asking if there is anyone with tube design experience reading this who would be willing to take a look at a couple of my design decisions (specifically my choice of tube thickness for the brake and the tabs of the MC-5 attachments, and whether the gusset is appropriate). Also, is there any reason that the rudder pedal won’t fit? I’m happy to provide the SolidWorks files and details on what I need reviewed.
Once I get this all settled and proven to work, I’m thinking of writing a long-form article explaining how to make this for S.net, complete with my SolidWorks files, in case anyone else would be interested.
By the way, next to the magazine, the fact that SolidWorks is free through EAA is hands-down their best benefit. I don’t have the strongest CAD background in the world. Yet, starting from scratch, it only took me about 3 hours to first draw the master cylinder, and another 20-ish hours to do everything else. About 2/3’s of that time was pure learning curve, but is well worth the effort! I can highly recommend getting SolidWorks if you are doing any kind of mechanical design. I will be doing a lot more of this.
O’Bill
O’Bill
