magneto leads replacement...
12,622
I was wondering if a feral was holding the wire in? As long as you can anchor the wire and have the wire end connects, it should work.
12,622
I bet it can be made to work. What you need to figure out is how to ground the outer sheath. This is the mag that the wires run into the side not the one that has a spark plug type connector?
