acrojohn
The gear leg MUST be allowed to flex independently of the fuselage longerons, bolts, and bushings. Many amateur builders don't see the real issue and believe adding more metal for strength and heavier clamping is the solution. Tight clamping of the gear leg to fuselage is a guaranteed disaster.
You must additionally consider loads placed on the longerons from heavy braking that require vertical reinforcement at the bolt/bushing/cluster attach points to distribute these loads. As I wrote before, this was a very common problem on planes like the Pitts, Christen Eagle, and experimentals that used a Grove gear leg without proper reinforcement. Aviat Aircraft (Christen and Pitts) has done the analysis and engineering to generate a bullet proof fix. This is documented in a Service Bulletin at: https://aviataircraft.com/wp-content/uploads/2016/01/e364.pdf. The basic design of the Sonerai I is easy to adapt without doing everything that the service bulletin requires. Think of the required adaptation being functional sufficient, rather than identical to the SB drawing. The Sonerai II LTS requires a bit more work if you want to move the Bolt Bushings and vertical reinforcement forward and aft of the gear leg to sandwich the gear leg between the radius bars rather than bolting through the gear leg to the fuselage. Although I have witnessed successful results of the original through the gear bolt attachment. If the original design is used (bolts through the gear leg), I suggest adding the radius bars using ample countersinks in the gear leg to allow it to flex on the radius bars. Consider the required clamping action on the radius bars from tightening the bolt/nuts to only be tight enough to just hold them in place. Read the Service Bulletin.
John
John
