slociviccoupe
anyone know of or working on a subie inverted oil system.
my thoughts are a billet dry sump pan, scavenge pump, sump with inverted oil puckup, and oem internal oil pump to supply oil taken from the tank.
some scavenge lines taken from the top of the engine case and valve covers with check valves in them plumbed to one stage of the scavenge pump to return oil to the tank when engine is inverted.
anyone have a picture of the inside of an inverted oil system oil tank. one i have seen is a swinging pendulem design that is weighted and weight on the bottom goes where the oil is.
i want to be able to do a loop and a barrel roll in the vision i plan to power with subaru power.
