how do you conduct a pitot-static test on an aircraft fitted with a venturi?
Discussion in 'Instruments / Avionics / Electrical System' started by Twodeaddogs, Oct 3, 2016.
  1. Oct 3, 2016 #1
    Twodeaddogs
    Twodeaddogs
    Twodeaddogs
    Jan 18, 2009
    815
    229
    Hi all,
    I was asked to do a pitot-static test on a Pa-22 Colt, which has a venturi fitted, as well as a pitot-tube on the left wing and static ports under the belly. How do you do a leak test on this set-up? Do you block off the venture?
    regards
    TDD
  2. Oct 3, 2016 #2
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    424
    570
    Tehachapi, CA
    One assumes that the venturi is used to power the vacuum instruments, yes?
    If so, then it's not connected in any way to the pitot or static lines, which are only connected to the altimeter, VSI, airspeed indicator, and transponder altitude encoder. So just like you can ignore the seat rails when conducting a leak test on the pitot and static systems, you can ignore the venturi.
    Or am I missing something else?
  3. Oct 3, 2016 #3
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,285
    3,025
    Mojave, Ca
    Yep. The venturi is the "muscle" to drive gyros... It has nothing to do with the pitot/static system.
    Lucrum likes this.
  4. Oct 3, 2016 #4
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,552
    1,552
    Upper midwest in a house
    +3, the venturi is irrelevant to a static test.
  5. Oct 3, 2016 #5
    fredoyster
    fredoyster
    fredoyster
    Mar 21, 2012
    333
    103
    Monterey Bay, CA
    Perhaps the correct response is to be *sure* that the venturi is not connected in any way to the pitot-static system, as it would surely give goofy readings if it were.
