Form Blocks
boltz
Dec 22, 2008
32
Australia
Hi,
I'm just about to start making form blocks for the plane I'm building and just have a few questions.
1. If the flange is going to be 1", is it ok to use 3/4" thick material for the form block? I could form the flange to about 80 degrees and do the rest out of the form block.
2. The block that you use to support the aluminium (not the one you're forming over), should it be smaller than the form block so that you can get the hammer in on the radius? Say 1/2" smaller? Or should it be the same size as the form block?
3. On bulkheads, has anyone tried making half form blocks? What I mean by that is if the part is symmetrical make a form block slightly bigger than half and form one side, rotate and then form the other. That way making it symmetrical.
Any other tricks that I should know?
Thanks
