Bendix king transponder
sailsail
May 20, 2009
United States
Hello all!
I have a kt76A (Bendix King) Transponder that I am wiring up to a Dynon Avionics Blind Encoder Converter that then goes to an Efis-d100. Anyway I am having trouble with the wire placement on the KT76A I have been to all the sites, including http://www.aeroelectric.com/Installation_Data/ and http://www.aeroelectric.com/Installation_Data/KT76A-76C-78A.pdf to get the wiring guide, the problem is the numbering does not match up! Using their convention the bottom of the fitting would be (right to left) A B C D E F G H I J K L and the top would be (right to left again) 1 2 3 4 5 6 7 8 9 10 11 12 (top works out perfectly) but they say it goes to N (top part) what letters do I skip? OR am I even doing this correctly?
Thanks for you help
Frank5105
Nov 11, 2009
1
Raleigh NC
Hi Dave
I am trying to find a KT76A installation manual also and tried to follow the link that you posted above with no success. The web page at Bomar is protected and I dont know how to get in?? If you have the PDF and would email it to me I would greatly appreciate it. fran[email protected] Thanks in advance Dave
s10sakota
Feb 9, 2003
18
Westland, MI (near Detroit)
Has anyone figured this out yet? I too am wiring a KT76A to a Dynon D-100 and I am using Dynons Encoder Converter.
I don't understand the numbering/lettering on the King plug. On page 7-34 of the Dynon manual it tells me to connect the:
Yellow to A1 (on the King plug)
Green to A2
White/Blue to A4
Blue to B1
Orange to B2
etc...
Which pin is A1? or A2, A4, B1 etc...??
This may be simple but I'm just not getting it!! I can see what pin A could be. Or I can count and find pin 7. But how are they combining them to get something like A4?
Thanks
djschwartz
Jun 21, 2008
982
Portland, Oregon
PM me with your email address and I'll email you the KT76 manual in PDF that I have. There is a drawing in there where King numbers the wires with A1 as they connect to a King encoder, etc and shows how those connect to the actual pins of the KT76 connector. The guys at Dynon must have used the wrong set of identifiers in their diagram.
s10sakota
Feb 9, 2003
18
I figured it out! okay...actually I didn't figure it out but someone told me how they are labeled. Dynon has it correct-I just didn't realize that B1 for example is really pin E.
Thanks!
llacy
Apr 21, 2010
1
Decaturville, Tn
I am wireing a kt76a to the dynon converter and am having the same problem numbering. Can someone give an example of the Dynon numbers to connect to the KT76A.
Lou Lacy
chuckb01
Sep 12, 2010
1
South Beloit, Illinois & Almond, Wisconsin USA
Lou Lacy
I realize this is an older thread but I just joined this forum and I need all the same info. I need a installation and operators manual for a Bendix/King KT76A TSO transponder and I am also installing the Dynon alt. encoder converter to be used with my Dynon EFIS D10A. I need wiring info for all this stuff. Thanks for any help.
Geoffrey Thorpe
Dec 1, 2009
67
Downriver from Detroit MI, US.
http://www.flycorona.com/manuals/king_kt76a_kt78a_install.pdf
What this manual doesn't tell you is the "missing letters" from the connector scheme - the G and I are missing. If you find a KT 76C manual it has a diagram with all of the pins labled.
Mollex connector pin part number 08-03-0304 - Available from Mouser.com - their number 538-08-03-0304 - order extras...
bsair
Oct 29, 2013
1
Reedley, CA
Hello all!
Thanks for you help
FYI
Pin-out letters G and I are not used in this plug because "G" may be mistaken for a "6" and "I" for a "1".
The lettered pin-outs on this 24 pin plug are: A B C D E F H J K L M N and the numbers are 1 through 12
Hope this helped.
C
