1/2 VW power output??
radfordc
Feb 5, 2008
1,479
What kind of static thrust do they get out of one anyhow? With "30 hp"
Not a lot! I built a 35 hp 1/2 VW for my old Airbike. Here are some comparisons to the Airbike with a Rotax 447 engine.
447 takeoff roll about 200 ft; 1/2 VW takeoff roll about 400-500 ft.
447 rate of climb about 700-800 fpm; 1/2 VW rate of climb about 300-350 fpm
The difference in performance is due to the relatively small prop that the 1/2 VW turns in comparison to what a 447 can turn with gear reduction. A small prop produces less static thrust than a large prop.
N8053H
Jan 31, 2013
2,523
If you go with a different crank one with longer throws you can squeeze a little more out of these little 1/2 vw's. I believe Scott said mine was 1000cc. It had the bigger jugs, pistons and crank. It also ran great. Pulled a 650 lbs airplane around great at 3100 rpm on climb out.
addicted2climbing
Jan 27, 2012
1,337
Glendale, CA
Was yours built from the cut case or full? Any idea what the FWF install weight was? What was your impression on this motor?
10,635
Friend of mine put a thousand hours on a 37 hp, 1/2 VW in a Mini-Max with no problems. Decided to do a MOH. Him and an old WW-2 fighter pilot flying another Mini-Max did a formation routine at airshows for several years with the 2 MM's.
10,662
Mosler claimed 40HP for their 1083cc CB40 engine (a half VW with a custom case and crank) I had in my Fisher 404 biplane, but most said it was less, maybe 37HP. I got 300-350fpm on a good day, but the plane was designed for the 50HP Rotax 503.
addicted2climbing
Jan 27, 2012
1,337
Glendale, CA
[video=youtube;wCRCggFYmMI]https://www.youtube.com/watch?v=wCRCggFYmMI[/video]
Wow that is surprising and the Mosler has a higher CC than the Cassler modified engines. I really want to use the 1/2 VW on the skylite, but seems the more I read its a marginal option. However the Legal Eagle at our club seems to do pretty good. What was the empty weight of your fisher 404? What was the weight with you in it and full fuel? The more I go back and forth the more the Polini Thor 250 looks good. Also there are a bunch of 250CC 4 stroke PG motors but they are all set up as tractor only. Or at least the ones I have found are.
10,662
330 empty and 540 gross if I recall correctly. Its performance was far from breathtaking but I had a lot of fun with it. What made the half VW worthwhile was the sound it made (no 2-stroke whine, which is just wrong on a biplane) and the 2GPH fuel consumption, less than half of what the 503 would burn.
N8053H
Jan 31, 2013
2,523
A friend has a Mosler on an N3 pup. This engine has some compression. Hand propping that engine is a BEAR. My buddy has not put but a few hours on it and we are hoping it loosens up some or gets easier to hand prop. But I do not see this happening. The Cassler 1/2 vw is a cut case. I did like that engine, she ran great. The airplane she was in with a pilot and full tank of fuel tipped the scales right at 600 lbs. This was with a 190 lbs pilot. Gross was 650 lbs. When I purchased her she weighed 650. I put her on a diet.
16,809
Some of that biplane drag was for sure part of the slow climb. The LE really jumps in the air.
ryanjames170
Apr 29, 2012
146
Rice lake and Hayward WI
Very true 330lbs vs 244 for 30-40hp dose add upto quite a difference.
Beginning to think though a few V twins can be made to work too, have to leave the airplane world and go to the tractor go cart racing world to find the info..
