V4 1/2 LS
Discussion in 'Chevy' started by pictsidhe, Jul 5, 2019.
  1. Jul 5, 2019 #1
    7,234
    2,069
    Not made by GM, but just came across an interesting V4 based on the LS series. 1650cc, 150lb. Peak torque of 126ftlb. At a piston speed of 2500fpm, power is ~135hp at 5600rpm. Would need a redrive. I saw in an article that the crate engines are $10k.
    Motus V4
  2. Jul 6, 2019 #2
    sotaro
    sotaro
    sotaro
    Feb 27, 2011
    122
    16
    San Francisco
  3. Jul 6, 2019 #3
    mm4440
    mm4440
    mm4440
    Jan 14, 2012
    182
    38
    LA area, CA
    I have read that they are are still making the engines, but not the motorcycles. The price is a bit higher. they have similar features to an LS but are more compact than a 1/2 LS would be. Years back SCAT made a 1/2 sbc of 200 cu in. I do not know if they are still around. The Samson roadable aircraft prototype has a turboed Motus. With a good conversion, the Motus would be a great little experimental aircraft engine; light and compact.
  4. Jul 6, 2019 #4
    7,234
    2,069
    The price is not appealling, but the weight and power look good.
  5. Jul 6, 2019 #5
    John wadman
    John wadman
    John wadman
    May 27, 2019
    204
    250
    I wonder how hard it would be to cut a block in half and rework water jackets, oil system etc. rockers, cams, all would have to be reworked.
    poormansairforce likes this.
  6. Jul 6, 2019 #6
    7,234
    2,069
    It's been done. The half VWs are air cooled engines that are basically sawn in half. Water cooling would involve welding up water jackets for a little more fun, that has been done too. The only one I can think of was a Merlin getting 10 cylinders lopped off...
  7. Jul 6, 2019 #7
    11,933
    3,417
  8. Jul 6, 2019 #8
    Bill-Higdon
    Bill-Higdon
    Bill-Higdon
    Feb 7, 2011
    476
    145
    Salem, Oregon, USA
    GM back in the 60's made a 4 cylinder the Trophy 4 it used RHS bank of a 389 IRCC
  9. Jul 6, 2019 #9
    Angusnofangus
    Angusnofangus
    Angusnofangus
    Sep 29, 2015
    330
    143
    Victoria, Canada
    You remember correctly. At one time I had a 1961 Pontiac Tempest with that engine in it. Don't remember much about it except it burned just about as much gas as if it was a 389 and the distributor had a rattle in it at idle, something to do with the advance mechanism I think.
  10. Jul 6, 2019 #10
    7,234
    2,069
    A direct drive V-twin 'LS3/4' is more like our size. 1540cc, 106ftlb. Maybe 120lb +rad if you make a lightweight manifold and pan. Stick a turbo on and it would be very appealing.
  11. Jul 6, 2019 #11
    poormansairforce
    poormansairforce
    poormansairforce
    Mar 28, 2017
    699
    195
    Just an Ohioan
    This is where my mind has been hanging out.;)
  12. Jul 6, 2019 #12
    11,933
    3,417
    You always have the old Ford V4 like used in the SAABs and the Lancia V4s if you just need a V4.
  13. Jul 6, 2019 #13
    CharlieN
    CharlieN
    CharlieN
    Sep 7, 2018
    38
    25
    Vermont USA
    You state this Motus motor is based on a GM LS engine, yet there is no dimension or part that is even close to any production GM engine.
    This looks to be a clean sheet design if not shared tech from somewhere else.
  14. Jul 6, 2019 #14
    7,234
    2,069
    Yes, but they weigh about the same as a whole LS.
  15. Jul 6, 2019 #15
    pilot103
    pilot103
    pilot103
    May 13, 2003
    101
    21
    I just read an article this morning about the Ford V4 in the April issue of Classic Car, according to them it weighs 265 lbs.
  16. Jul 8, 2019 #16
    John wadman
    John wadman
    John wadman
    May 27, 2019
    204
    250
    Wonder if it would work in a pietenpol.
  17. Jul 9, 2019 #17
    mm4440
    mm4440
    mm4440
    Jan 14, 2012
    182
    38
    LA area, CA
    Yes it is a cast iron boat anchor as was the model A engine.
    pictsidhe likes this.
