fadec
Before anyone gets too excited this isn't a new engine, just a historical curio that may be of interest to some folk here. I came across it in a book on the Stinson Voyager by John Swick.
The engine was designed by Fred Thaheld. The prototype engine was flown in a Stinson 10A around 1946 and was intended to be produced by Diesel Power Inc in California but at that point it seems to drop off the radar. There is very little other info on this engine and I don't know what its eventual fate was.
Air cooled, horizontally opposed, direct drive
Fuel injected
Weight 235 lbs without accessories
100 and 125 hp versions (at 2400rpm), from what I can gather the only difference between the two is in the fuel injection systems
Displacement 290 cu.in
Compression ratio 16:1 (but could still be hand propped apparently)
SFC is claimed 0.2 at cruise
Cylinders have Al heads and steel barrels with 1 exhaust and 1 intake valve per cylinder, pushrods with overhead rocker assy
Dry sump (though note sump in Popular Science link below)
Al pistons
Cast Al crankcase
Coffman cartridge starter and is said to start easily when engine is hot or cold
Said to have a much shorter warm up time than its gasoline comtempoaries
picture of whole engine here (skynet won't let me post the image)
http://books.google.co.nz/books?id=...CCQQ6AEwAQ#v=onepage&q=thaheld diesel&f=false
disassembled engine image from Swick's book
Fuel injected
Al pistons
Cast Al crankcase
