Flyguyeddy
- Jun 9, 2018
- 446
You should pull the heads.
Upgrade NowIf you have dual-plug heads, you can do the opposite. Blow air in the cylinder from the other plug hole while running the tap and the cuttings should stay out of the cylinder entirely. Greasing the tap catches a lot of cuttings too.Glad I asked - I didn't know of the rental option! Thanks both!!
To clean out the cylinder afterwards did you use the Shop-Vac suggestion? Bill, I was thinking the same.
Todd - did you use the 44127 insert?
Only the 14mm is easy to rent but I see this list now owns a 10mm and I have the 12mm kit. I am sure most would be open to covering post and replacing if booger-ed up. They are quality tool steel and should be good for 1000's of holes. I will double down and second the recommendation you pull the heads! Nuff said! You are the Mechanic in charge. The Process provides excellent feedback and you can feel the insert being pressed into the walls of the head you know when you are done. Note: The Process Video is for the non spark plug tooling but it demonstraits the way they are locked in secure. This company was a quite little know company providing the government solutions for area 51 since the 50's until FORD came out with the long reach plug popping Triton engine with only 3-5 threads at the bottom of the hole. A $400 kit was a fraction of pulling the heads and fixing the traditional way. Since then they are on the map and available to a all. You will not regret using them.Install kit rental ordered!
Frankly I don’t remember the part number. I rented the tool and purchased the time-sert from the same place (aircooled.net). My heads are stock VW single-port with 14 mm spark plugs and 1/2” reach. The insert I used was copper. The tools, inserts, and process is all very high quality.Todd - did you use the 44127 insert?
Enter your email address to join:
