Rivet gun recommendation
10,870
I'm considering purchasing a rivet gun.
Live looked at the Eastwood rivet gun set here
http://www.eastwood.com/solid-rivet-kit.html
i would appreciate comments about it or recommendations towards a decent one.
Bill
Georgia
I would think twice about that, their listing does not mention whether it is a 2X, 3X, or whatever size/strength rivet gun. Their description talks about automotive use "similar" to aircraft stuff.
If you are going to want to use this gun to build airplane stiff, you will find a 2X gun does 3/4 of everything you need other than the small number of large rivets (5/32 and 3/16) for large attachments. I would go with a genuine aircraft quality gun. Some others here have bucked many many MANY more rivets than I have, so their recommendations should be taken as more gospel than mine.
What kind of work are you planning to do???? Build a full scale F-4, small trim tab repairs on a Hummel Birrd, build an RV-8 tail kit, repair a Cessna aileron???? The chioce of tool will be more based on what you will be us ing it for than anything else.
EDIT: I have only a 2X size gun, 95% of all my sheet metal work uses 3/32 and 1/8 size rivets, and this gun is enough to do that. If I were starting an RV project (sound of knees knocking) I would go out and get a 3X, but I'll bet 3/4 of the airplane could be built with the 2X.
billyvray
Aug 17, 2005
965
Newnan, GA
Yeah a brief search has clued me in a bit. I'm looking at a 2x or 3x kit. I want to play with aluminum angle and thin sheet structures.
rbrochey
Oct 17, 2010
1,569
Gallup, New Mexico USA
Robert Baslee at Airdrome recommended this one to me... about forty bucks at HF... and it works great, I have no issues with aluminum riveting...
billyvray
Aug 17, 2005
965
Newnan, GA
That works great for blind rivets, but I'm looking for a solid rivet gun.
I've just about settled on the ATS 3x gun I think.
Angusnofangus
Sep 29, 2015
601
Victoria, Canada
I think you will find the ATS will do nicely. I have a 3X rivet gun that I have used for more than 25 years, US Air Tool IIRC. Great gun, very sensitive trigger. The trigger feel is the most important thing. Just use dry air and a couple of drops of air tool oil regularly, and it will last for years.
billyvray
Aug 17, 2005
965
Newnan, GA
Thanks guys for the thoughts. I think I've made up my mind with at least a better tool to start with.
Bill
