Lucrum
New never used CXRacing Turbocharger. I just figured out I didn't do a very good job of matching the turbo compressor map to my application. Includes 3" Turbo V-Band Clamp & Downpipe Flange and T4 turbo Manifold flange Divided Center.
I have $697 tied up in it. While I will consider any serious offers if I can't sell it without taking too big a loss I'm just going to use it anyway.
Description:T76 1.15 A/R P Trim Turbo Charger
- 4" Air Inlet
- 2.5" Compressed Air Outlet
- Wet Floating Bearings
- Oil + Water Cooling
- 1/8" NPT Feeding. M8 x1.25 Return Flange Mounting Screws
- M16 Threaded Water Cooling Fitting
- Standard T4 Flange
- 500-800 HP
- 76mm Wheel Compressor
- P Trim 1.15 A/R Turbine
- 102.4mm/76.7 Compressor Wheel
- 74.1mm/64.6mm
- 3" V-band Hot Side
- 4" Air Inlet
- 500-800 HP
- 74.1mm/64.6mm
