Marquart MA-5 Charger Construction Plans Sheets/Technical Manual
Rushcity
May 1, 2023
1,837
Technical manual/Plans (23 sheets) related to the construction of Marquart MA-5 Charger
MA-5 plans sheets attachments 1-8
  • MA-5 Sheet 02 - Upper Wing Assembly.pdf
  • MA-5 Sheet 03 - Lower Wing Assembly.pdf
  • MA-5 Sheet 04 - Wing Ribs.pdf
  • MA-5 Sheet 05 - Wing Spars.pdf
  • MA-5 Sheet 06 - Upper Wing Fittings.pdf
  • MA-5 Sheet 07 - Compression and Drag Fittings, Upper Wing Fittings.pdf
  • MA-5 Sheet 08 - Wedge Blocks, Wing Fittings, Rib Supports.pdf
  • MA-5 Sheet 01 - Two View.pdf
MA-5 plans sheets attachments 9-16
  • MA-5 Sheet 09 - Lower Wing Fittings.pdf
  • MA-5 Sheet 10 - Aileron Assembly and Fittings.pdf
  • MA-5 Sheet 11 - Aileron Bellcrank and Brackets -Lower Wing Fittings.pdf
  • MA-5 Sheet 12 - Fuselage Frame.pdf
  • MA-5 Sheet 13 - Fuselage Details.pdf
  • MA-5 Sheet 14 - Fuselage Details.pdf
  • MA-5 Sheet 15 - Cowling, Formers, Stringers.pdf
  • MA-5 Sheet 16 - Landing Gear and Engine Mount.pdf
