Epoxy Cleanout
Discussion in 'Workshop Tips and Secrets / Tools' started by Lee Schaumberg, Mar 19, 2005.
  1. Mar 19, 2005 #1
    Lee Schaumberg
    Lee Schaumberg
    Lee Schaumberg
    Aug 28, 2003
    215
    Northern Wisconsin
    The two compartment epoxy pump that I have needs to be cleaned out. The plastic containers are available all over What chemical will remove the epoxy and resign?
    Lee
    _______________________________________________
    Seek and you will find!
    :ban:
  2. Mar 19, 2005 #2
    orion
    orion
    orion
    Mar 3, 2003
    5,800
    135
    Western Washington
    As long as the epoxy is not catalyzed and cured, the components can be removed with Acetone, MEK, or alcohol, although with the latter it's a bit more work. The benefit to the alcohol though is that it's not as caustic. MEK I'd recommend only as the last resort.
  3. Mar 19, 2005 #3
    Lee Schaumberg
    Lee Schaumberg
    Lee Schaumberg
    Aug 28, 2003
    215
    Northern Wisconsin
    Epoxy Pump Clean Out
    Orion
    Thanks for the info.
    Lee
    Amazing the things you find when you look. :ban:
