inventing_man
- Joined
- Aug 30, 2008
- Messages
- 108
I'm looking for information on what OD size and alloy shaft to use for mounting a prop hub to . It will be a 64 -66 inch 3 blade , more than likely a GSC The reduction is belt drive and a stand alone . Not a gear box . The Drive shaft will be 16 inches long. What size shaft is needed and what configuration ( taper, threads, key way, Taper lock ? ) would the prop end need ? Any input is welcome , Pics would be nice , Thanks!
