Hi folks,
I am guessing some of you may have noticed that the return spring rates on the Beringer master cylinders is quite a bit higher than Groves and others.
The calculate out to me to be about 2N/mm. I have rocker toe brakes so that I can manually return.
Has anyone looked at fitting lower rate springs to improve progression and reduce overall pedal loads? If so what rate did you settle on?
