CdnMedic
So, the biggest thing that kept me from building a Sonerai is flying it from the rear seat. However, there are always compromises in any airplane so I decided to go with a 2L and just deal with the fact of flying from the rear.
But, people have figured out configurations to solo from the front, so I've been working it out in my brain how to make it work.
I took Scott's weight and balance spreadsheet, moved some things around, and with moving the fuel tank behind the seat, mounting 2 batteries at the tail post, and having the pilot in the front seat with the seat "moved back" a few inches as shown as a mod in one of the news letters, I can get the cofg with the pilot in the front and an empty tank to being at 7.95" (pilot weight is max 180lb). So barely out of limits.
I'd be well within the aft limits with a full 15 gallons in the tank and a passenger.
I didn't include the weight of things like dual fuel pumps (my engine is fuel injected) and since I'm going glass cockpit I can move a few things to the tail like radios and whatever else... I'm not a huge fan of loading the tail with weight in the event of a flat spin (extra momentum).
So, the idea popped in to my head to keep the firewall back to the station at the rear spar stock as a normal 2 and then build the back half as a stretch. The extra moment of the longer tail gets the cofg behind the 8" and the length helps stability. The tank (15 gallons) would still be behind the rear seat.
I'm not a tall fella so the "cramped" front cockpit doesn't bother me.
I realize this is departing from what a Sonerai truly is, but it is experimental aviation. It isn't super far off from a few things others have done, and this isn't a very drastic change.
I'll never have this plane flying below aerobatic category weight with me as a pilot, so I don't intend to have it weigh 550lb empty, but I don't want to add extra ballast or weight by doing things like covering the bird in aluminum just to bring the weight rearward.
Engine weight will be 180-190lbs, so it's close to the heavier VW options.
Thoughts?
Thoughts?
