Bil4381
- Joined
- Oct 17, 2007
- Messages
- 884
aircraft spruce sell a fixture, which goes on a drill press. You clamp the tube in the fixture which itself is clamped to the table of the drillpress.
I bought a HSS holesaw to drill the ends of the tubing. Use a metal tray, cookie sheet to catch the coolant. You need coolant for cutting chromoly, or the holesaw is burned in no time.
FWIW, I also had some welding done by an aerospace welder. he is coded. he uses an angle grinder (carefully) to notch the ends of the tubing. I think he had a cutoff wheel installed, but used that wheel for all the notching too.
