Flim63
My work is relocating me and I will be off any projects for a while, so the partial project I just bought is going to have to change hands again. The following is included:
welded 2LS fuselage with horizontal stab, elevator, however no rudder was made so that remains for the new owner. Fabricated to plans except the original builder made the turtleneck bow off-spec (vertical legs instead of angled. I was going to re-fabricate to plans for canopy installation ease) Cro-moly stock to make new bow included. Tail wheel installed
Full plans set with serial number
5/8" gear with wheels and mechanical brakes (tires flat, using them just as a roller)
Right spar fabricated and riveted with modded angle reinforcement. Left spar fabricated but not riveted. Will ship it clecoed for new owner to finish (trying to keep it under 49%)
rear spar kit materials
aileron kit materials
fiberglass cowl and wheel pants
<Engine parts>
AS21 VW case. I have not inspected this case but it appears NOS. This is the version that VW rodders seek for it's strength. Appears to have no mods from stock yet.
92mm Mahle pistons and cylinders (new). These are the style for a 82mm crank so ready for a 2180 build.
AMC heads drilled and tapped for dual ignition.
Flywheel and alternator.
Slick 4316 magneto and harness
Cam of unknown grind or condition
Diehl case
Zenith carburetor (NIB)
$3500. If desired, I can rivet the left spar and fabricate the new turtleneck bow for an additional $250.
Located in Warrenton, VA
capturedmotion<at>gmail.com
Jason
<Engine parts>
Diehl case
Jason
