BAILEIGH INC
The MH-19 Power Hammer from Baileigh Industrial offers serious performance for today’s demanding craftsmen.
Three forms of metal working machines are incorporated into one unit making the MH-19 one of the most versatile pieces of equipment on the market.
Solid hit mode enables the user to select a fixed stroke depending on the tooling and material being formed. This is useful when performing mechanical shrinking, stretching, or beading applications. Similar to an “Eckold” or “Pullmax”.
A flexible or “slapping” hit is easily achieved by simply removing one externally accessible engagement pin. Once this is done aggressive shrinking, doming and planishing operations can be performed. Similar to a “Yoder” type machine.
Finally, an English Wheel attachment is included with every Power Hammer.
The tooling for the MH-19 is as unique as the machine itself. Quick release pins make quick work of tooling changeover. Custom dies can be made to your specifications or choose from a selection of standard die styles.
All functions of the Power Hammer are designed to increase productivity through ease of use. Stroke length and tooling clearance is adjustable “on-the-fly”. Choose from either foot pedal or automatic control. Maximum beats per minute is easily set via an adjustable dial. A hand wheel allows the operator to cycle the machine manually for simple tooling setup.
