Armilite
Has anybody seen this Combo a Skidoo/Rotax 335 Single & Belt Drive being Sold on eBay? Has Electric Start Option, but No Starter. Who made these Belt Drives? ROTAX 335 CC Ultralight , Trike Paraglider engine REDUCTION MOUNT AIRCRAFT | eBay
The Skidoo 335 (78mm x 70mm) 334.6cc, 9.0cr is 20hp@5500rpm with a Can Muffler, probably 24hp@6500rpm as is! I believe it used a 30mm Carb.
The Skidoo 340 TNT (78mm x 70mm) 334.6cc, 38mm Carb, 10.5cr is 26hp@6500rpm with a Can Muffler!
The Skidoo 340 Blizzard (78.5mm x 70mm) 338.9cc, 38mm Carb, 11.8cr is 36hp@????rpm with a Tuned Pipe!
The 340 TNT & 340 Blizzard Singles used a better Ported Cylinder and can accept Bigger Carbs I think up to 44mm. The 335 was limited to 34mm without Machining!
