John Monnett said:I understand that the original designer highly recommends the AeroVee 2180 as a lightweight full featured engine for Sonerai 1 and 2! But, then again what would he know...
splischke said:Schmleff said:... Its too early to tell, but the 2276 that uses 94mm jugs cut at the base to fit the 90.5/92mm hole might be the way to go (in that displacement). It leaves the most meat in the case and give you the cylinder wall thickness where needed (at the top).
You are referring to the slip-in 94mm jugs we talked about last year? See http://www.sonerai.net/CMS/index.php?option=com_jfusion&Itemid=160&jfile=index.php&topic=1113.0. I'm tempted.
Hans said:Chad,
thank you for clearing that up. So you think that slip-in 94mm's would be ok if one - like me - is not going for all out power but for maximum durability?
cheers
Hans
tonykasabasich said:I really need some advise here.
I'm ready to build the motor. I'm set on doing 94mm pistons with an 84mm crank. I've got an Empi Alum case and a few sets of dual port heads. That's about it so far.
So the crank has me scared to death. My choices range from a billet Scat at 1200 bucks all the way down to junko Chinese at 189 bucks.
scat billet 4340 1200.00
scat forged 4340 475.00
cb perf forged 4340 275.00
empi forged 4340 250.00
chinese who knows 189.00
I've got an empi crank 4340 new sitting here. Do I run it or go buy a Scat? Forged or do I have to go billet? I'm way way out of money here so budget is a concern. I was gonna use the F1 hub. Does that protect me if I'm using a forged crank? Do I even need to run the F1 hub?
I've got a few mills here. I wanna drill my own heads for dual plug. Anyone got an instruction sheet on angle and location or a spare head they wanna loan me for a day? What plug size should I be running?
I can buy all the Empi parts I need at Wholesale prices. I did a buy in with a friend's VW shop. So I 'd like to use that big discount whenever I can.
Any advise is welcomed
Tony
