gahan
I have located a 582 rotax locally on a 2 seat pusher two plugs per piston oil injected starter with rotax gear box' it looks to be a real pro setup. i havent located to much info on this model engine but i've been told it has a rotary valve intake 35 years ago i rode a 100cc bridgstone motor bike with this rotary valve and it just screamed but they had trouble keeping the crank seals working do you think rotax solved the problem or will i have low Hr's between tear down'sout:
I have checked with Izon and I will be ok on weight and they provided info on beefing up firewall. cost is $1000 complete for motor I can't beat the bang for the buck.
