Quicksilver MX Sprint Main Gear Strength
Chris In Marshfield
Jan 29, 2008
1,706
Northwest WI USA
Good morning all,
A technical question before heading out for the big show. I recently installed Black Max brakes and new wheels/tires on the plane as you may have seen in my build discussion. A member of the QS FB community suggested that I created a "massive weak spot" in the gear and I should internally/externally sleeve the gear to carry the load. I don't know that I agree with that. The axle adapter that I removed was replaced with the exact same-sized adapter that was provided by Quicksilver. The axle that went in is the same diameter as the axle that came out. There was a bracket bolted to the adapter that supported the bands for the original brakes that was removed because it's no longer necessary. Not sure I see the weak spot unless that bracket provided some additional strength in its two-inch span.
If there's one thing I've learned from this group is that strengthening one thing usually moves the weak point somewhere else. I haven't heard any tales of woe from the QS community about axle tube failures. I am disinclined to acquiesce to his recommendation.
A3F3D29D-E8BB-46CA-B3A4-FE58B1FE48FC.jpegFF0A99E1-3E1A-429E-9B71-729F0DCDA518.jpegF7A706CC-DA91-4DB6-BF9F-555BE24CFA6C.jpeg14684EFE-CCD9-4687-A851-F861ED5BC7CC.jpeg
