We've just finished design and machining of a billet 45mm throttle body designed for engines in the 60-120hp range. Common applications would be VW, Conti O-100, O-200, Jabiru 2200, 3300, Subaru EA81, Suzuki 1.3/1.6, Rotax 912. The body is 6061-T6, throttle arms are 7075-T6, shaft is 304 stainless and blade is brass. Arms are available for either vertical or horizontal mounting. Optionally mounts a genuine Bosch TPS. The engine side has an O-ring groove for sealing and is mounted with AN3 bolts. Air side snout is 2 inches OD to take common K&N filters or SCAT tubing. Weight as shown with TPS is 240 grams. Can be anodized for a slight extra charge if desired.
Next on the list is an 80mm design to replace Bendix RSA-10 servos on Lycoming 540 engines which should be ready in late January 2016.
