New 80mm EFI Throttle Body RSA-10 Replacement
rv6ejguy
Jun 26, 2012
6,217
Calgary, Alberta, Canada
For those thinking of replacing Bendix style mechanical injection with EFI, we now have CNC'd throttle bodies to bolt directly in place of RSA-10 servos on forward facing IO-540 sumps. The throttle plate is 80mm and the air horn base accepts 4 inch ID SCAT hose, K&N filters or Silicone couplers. The TB has an O-ring seal on the base so gaskets are no longer required. The shaft is Stainless, supported on sealed roller bearings. The throttle arm is 7075T6 and incorporates internal stops. Under 2 pounds total weight and mounts an OEM Bosch TPS. There are no internal restrictions like on Bendix/ AFP servos so the body offers full manifold pressure potential up to 375hp.
