abosror1992
Invention is to build a plane from
the inside between the external and
internal surfaces of the blown
rubber.
Cross-section images of the plane
shows the location of the blown
rubber:
Invention reduce the aircraft
wreckage after the crash incidents to
increase the number of survivors.
This will help reduce the deceased in
aviation accidents by preventing the
collapse of the passenger
compartment, especially when the two
phases of landing and take-off.
As well as cover the fuel tank with
blown rubber for not leak fuel after
the crash.
There is also something else on this
idea is that after a blown rubber
inflatable will be in contact with
any of the surfaces, Will be floating
between the surfaces.
Because the cause of the dead people
in plane crashes, either because of
damage to the human body, or
bleeding,And the balloon inflated to
prevent ejection of the body to the
outside or access things outside of
the plane during the crash.
Blown rubber dimensions will not
exceed any dimensions of the air
plane's Tire About 30 cm , plane's
Tire was able to absorb the crash
while landing despite the presence of
friction and heat and motion.
Image of the plane's wheels, carrying
the plane:
Manufacturing steps:
1. Get on a plane.
2. Remove all what is not essential
from within the passenger
compartment, such as passenger seats
and the luggage locker.
3. Manufacture of hollow rubber
according to specific design
specifications and according to
certain dimensions obtained by the
previous step.
4. Installation of hollow rubber
inside the passenger compartment and
fill it with gas.
5.Installation of internal parts of
the aircraft, including the chairs
and other equipment.
this Invention Will increase the
demand for air travel.
Because the impact of aviation
accidents to passengers led to two
things: either to reduce air travel
for those traveling by air or not to
fly or to experience only once.
I want your opinion technically
rubber.
rubber:
the crash.
the plane:
1. Get on a plane.
previous step.
fill it with gas.
