has anyone ever used redwood for aircraft primary structure?
Aviacs
Mar 16, 2019
921
I always thought redwood was weaker than sitka spruce, but recent posts on wood work and substitutions got me digging in old literature.
For instance, "AIRCRAFT WOODS Their Properties, Selection, and Characteristics" , FPL, 1941
file:///C:/Users/Steven/Downloads/FPL_R1079ocr.pdf
indicates that redwood is slightly better than Sitka spruce in strength properties. In shock resistance and stiffness, it is rated 99% of Sitka spruce. Despite properties across the board of no less than 99%, Bending and compressive strength at 133% and hardness 110% of Sitka, that report weights specific gravity and puts the over all comparison of redwood to Sitka at 93% because they find the specific gravity to be 110% of Sitka.
Other recent research finds redwood to be slightly lighter than Sitka spruce. Including Wood database with Sitka @ 27lbs/cu ft, and redwood @ 26.
However, that source finds redwood to be significantly weaker, lumping old growth with new growth averages. Then they add this note:
Comments: ...........(snippage about old growth habitat)......
"Redwood lumber is very soft and lightweight, with a decent strength-to-weight ratio. It is also exceptionally stable, with very little shrinkage or seasonal movement. The mechanical values listed at the top of the page represent the averages between both old-growth lumber and second-growth lumber. On the whole, old-growth lumber tends to be slightly heavier (29 lbs/ft3 versus 26), harder (480 lbf Janka hardness versus 420), and stronger (10,000 lbf/in2 modulus of rupture versus 7,900) than younger second-growth lumber.
IOW, right in with Sitka spruce averages.
I've never heard of a redwood airplane, though. Perhaps during the era that redwood was plentiful and hence cheap everywhere as a mere utility wood, Sitka spruce was probably almost as common (ladder stock, e.g.) and even cheaper? Is it superstition, or intrinsic defect that makes it a liability for AC construction?
