wizzardworks
I am about to build some wing moulds for my plane. There will be plywood formers lined with 7/32" 5 ply underlayment. I need to coat all surfaces of these wooden parts
so that changes in humidity won't rershape my airfoils. I am thinking of using polyurethane furniture finish on everything before assembly. Also I don't much like screwing
the sheating down because it would likely dimple the surfaces and require filling. Small finishing nails would be slightly better and a few to hold things in place while
bonding with some kind adhesive should be doable. The question is what would stick to things encased with two coats of polyurethane?
wizzardworks
wizzardworks
