battery starter for Cont C 75-12F, C 85-12F, C-90-12F and the O-200.
13,355
I'm using a C-85-12F with the starter and Generator remove and the holes covered with aluminum plates. What do you think of using a 90 deg battery powered drill to power the standard starter ratchet starter gear. Would need a 90 degree housing machined with bearings and made to attach the drill body to the housing. This 20 volt drill has a low RPM setting of 650 rpm. Weight- 3.25 lbs. Solder wires to the switch and install a switch on the instrument panel.
Just thinking out loud.
https://www.amazon.com/DEWALT-DCD74...B007ML7DHS/ref=psdc_552794_t1_B0052MII3C?th=1
