One of two Interesting articles I ran across while researching ballistic panel construction.
http://article.sapub.org/10.5923.j.cmaterials.20120205.04.html
International Journal of Composite Materials
p-ISSN: 2166-479X e-ISSN: 2166-4919
2012; 2(5): 92-96
doi: 10.5923/j.cmaterials.20120205.04
The Effect ofSilicon CarbideAddition into Fibreglass Reinforced Composites
Júlio César dos Santos ,
Rubens Bagni Torres ,
Luciano Machado Gomes Vieira ,
Zélia Maria Velloso Missagia ,
André Luis Christoforo ,
Túlio Hallak Panzera
Departmentof Mechanical Engineering, Federal University of SãoJoão delRei (UFSJ), São João del-Rei, 36.307-352, Brazil
Correspondence to: Júlio César dos Santos , Departmentof Mechanical Engineering, Federal University of SãoJoão delRei (UFSJ), São João del-Rei, 36.307-352, Brazil.
Copyright © 2012 Scientific & Academic Publishing. All Rights Reserved.
Abstract
In today’s modern world the composite materials have been widely used not only for aerospace/aeronautics, but also automotive, sports and construction industries. The flexural strength of laminated composites depends on the characteristics of dispersive and matrix phases, considering the presence of tensile and compressive loadings. For this reason, the addition of particles into the matrix phase has been investigated to enhance its stiffness and consequently the elastic modulus of the composite. This work investigates a glassfibre composite reinforced with silicon carbide particles. The following responses were evaluated: apparent density, water absorption, flexural strength, modulus of elasticity. The results were compared to those manufactured with no silicon carbide particles. It was observed that the silicon carbide particles provided the increase of the apparent density and flexural strength of the composites.
Keywords: Laminated Composites, Silicon Carbide, Fibre Glass, Hybrid Composites
Cite this paper: Júlio César dos Santos , Rubens Bagni Torres , Luciano Machado Gomes Vieira , Zélia Maria Velloso Missagia , André Luis Christoforo , Túlio Hallak Panzera , "The Effect ofSilicon CarbideAddition into Fibreglass Reinforced Composites",
International Journal of Composite Materials, Vol. 2 No. 5, 2012, pp. 92-96. doi: 10.5923/j.cmaterials.20120205.04.
Article Outline
1. Introduction2. Materials and Methods 2.1. Epoxy Resin 2.2. Reinforcements Phases 2.3. Experimental Conditions 2.4. Manufacture 2.5. Methodology 2.5.1. Relative density 2.5.2. Water Absorption 2.5.3. Flexural Stress 2.5.4. Modulus of Elasticity3. Results 3.1. Relative Density 3.2. Water Absorption 3.3. Flexural Strength 3.4. Modulus of Elasticity4. Conclusions
1. Introduction
The growing demand of composite materials has increased the attention to the theories of reinforced materials and advanced processes for their production.Some industrial sectors, as the areas of missiles, rockets and aircraft, owned the restricted use of structural polymeric materials or advanced polymeric materials. Following decades of restriction, modern industries have expanded the use of these materials. The automotive, sports and construction industries[1,2] have experienced an increase of this technology every year due to their superior specific strength, lower density, higher corrosion resistance and high strength/modulus over conventional materials[3,4].Replacement of metals by composites in commercial aircraft prime structures has been rapidly increasing to achieve further structural weight saving and reduce fuel consumption with a background of globally soaring oil prices[3].Brazil has expanded their experience of innovation in the application of structural composites, especially in the aeronautics sector, using for external and internal planes/ helicopters (about 20% of the area of an aircraft) and a lesser extent for structure of rockets[3].The dynamic flexural loadings in aircraft fuselage must be considered in the structural design. In this case, the composites must provide high stiffness and fatigueresistance[5, 6].The modification of the mechanical behavior of polymers by the addition of filler materials have shown a great importance in researches and has lately been a subject of considerable interest[7,8].In order to increase the flexural modulus of laminated composites, ceramic particles have been added in the matrix phase to enhance the mechanical performance of laminated composites. Flexural strength of laminated composites can be improved with ceramic particles[9]. Silicon carbide (SiC) particles can improve thermal responses of polymers[10] and some mechanical responses[11] of laminates.This work investigates the physic-mechanical properties of hybrid polymeric composites reinforced with glass fibre and silicon carbide particles. The fatigue resistance and thermal properties will be the scope of future investigations.
2.1. Epoxy Resin
The epoxy resin was supplied by M/s. Alpha Resiqualy Company (São Paulo, Brazil). The addition of 66.66% of resin (RQ-0100RF) with 33.34% of hardening agent (RQ-0164RF PLUS) was mixed to obtain the matrix phase.
The glassfibre fabric of 240 g/m2 was used in this experiment. The silicon carbide particles were supplied by M/s. Saint Gobain Company (Barbacena, Brazil) with particle size between mesh 200-325.
The glass fibre reinforced composites were investigated by the use of matrix phase non-modified and modified with silicon carbide particles.
2.4. Manufacture
The specimens were fabricated by hand-lay-up process[12] according to the recommendations of Vison and Sierakowski[13] (Fig. 1).For this research, the silicon carbide particles were sieved in mesh 200 - 325 US-Tyler (the particles retained on 325 US Tyler, were used).By volume percent, the composite was shared in 30% of reinforced phase and 70% ofmatrix phase.Three layers of glass fibre were cut into squares of 200 x 150 mm. Then, the mass of fibre was measured and the fibre volume of composite was calculated according eqn. 1:
Where is the mass of fibre and (2,5 g/cm3) is the density of fibre. According eqn. 2, the volume of matrix was obtained:
After, by density of matrix (1,16 g/cm3), the matrix mass (mm) was obtained according eqn. 3:
| Figure 1. Hand lay-up method |
| Figure 2. Silicon Carbide addition |
The weight of particles mass was based in 20 wt.% (this amount was based in results of[14]). The silicon carbide particles were mixed into epoxy resin matrix, manually.Later, the matrix reinforced with particles, was used for laminating of the three layers of glass fibre.The Armalon® demoulding sheets were used at the bottom and upper surfaces in order to ensure a goodsurface finish,as shown in Fig. 2.The samples were cured under room temperature, under 20 Newtons of uniaxial compressive forces, for 7 days.
2.5. Methodology
The apparent density was obtained according to ASTM SD792[15]. Test method a for testing solid plastics in water was used. By eqn. 4 was possible to calculate the relative density (rd) of sample:Where: a (apparent mass of specimen, without wire or sinker in air), b (apparent mass of completely immersed and of the wire partially immersed in liquid) and w (apparent mass of totally immersed and of partially immersed wire)[15].
The water absorption was measured according to ASTM D570[16].The specimens were immersed in saturated distilled water for 24 hours at 23ºC. The water absorption was calculated as follows:Conditioned weight: is the mass of sample immersed in water.The percentage of soluble matter lost during immersion, was determined by using the eqn.6.Recond. weight: mass of sample reconditioned in water after removal of there.The percentage of water absorption was calculated dividing eqn.1 by eqn.2.
The samples were prepared according to ASTM D790[17], based on the recommendations of materials less than 1.6mm in thickness.The flexural strength was calculated by Eqn. 7.Where P is the load at a given point of load-deflection curve, L (25,4 mm) is the support span, b (12,7 mm) is the width and d (mean of 1,28) is the depth of beam tested.
The modulus was obtained by the tangent modulus of elasticity in the ASTM D790 as follows:Where L (25,4 mm) is the support span, b (12,7 mm) is the width of beam tested, d (mean of 1,28 mm) is the depth of beam tested and m (calculated by graphic) is the slope of the tangent modulus (obtained by 50% deflection relative of the maximum flexural strength force).
3. Results
The comparisons between the results were carried out based on the Hypothesis Test for Difference of Means with Unknown Variances[18]. This analysis is able to verify whether the factor significant affects the response variables. The statistical analysis was performed for the flexural strength and modulus of elasticity responses. The other responses were analyzed based on the average and standard deviation of the experimental results.Table 1 shows the means and standard deviations for each response variable.
Table 1. Means and standard deviations |
Variable Response | Without Particles | With particles | | | Mean | SD | Mean | SD | | Relative density | 1.56 | 0.096 | 1.63 | 0.005 | Water absorption | 5.83 | 0.056 | 2.69 | 0.008 | Flexural stress | 50.86 | 5.27 | 73.0806 | 9.63 | Modulus Elasticity | 6.65 | 0.77 | 6.63 | 0.44 |
Table 2 gives the amounts for the hypothesis test for two averages. The confidence of 95% was set, which corresponds to an α =level of 5%.
Table 2. Test: Hypothesis test |
V. R. | Hyp. | tcalc | ttab | Concl. | Relative Density | H0: µ1= µ2H0: µ1> µ2 | 6,52 | 1,81 | Reject H0 | Flexural strength | H0: µ1= µ2H0: µ1> µ2 | 4,52 | 1,81 | Reject H0 | Flexural modulus | H0: µ1= µ2H0: µ1> µ2 | 0,048 | 1,81 | Accept H0 |
The comparison was performed between two means based on the t-student distribution, calculating the value of the “t calculed” and comparing with “t tabulated”. When the value of “t calculated” is outside the region of acceptance covered by the “t tabulated data”, then the initial hypothesis (Ho) is rejected[18].
The apparent density values of the composites varied from 1.50 to 1.63g/cm3. Fig. 3 shows the density graph for both conditions. The addition of siliconcarbide particles leads to an increase of 4.15% in apparent density of the material. This behavior was expected due to the higher density of silicon carbide particles.
| Figure 3. Graphic for Relative density |
The water absorption values of the composites decreased from 1.89% to 0,98%. Fig. 4 shows the water absorption graph for both conditions.The silicon carbide addition provided the reduction of 45.97% on the water absorption of the composites. Like the research of[11], one barrier properties appears, by the high loading of silicon carbide, covering the fibres. This layer of particles under the fibres, promoted a decrease of water absorption.
| Figure 4. Graphic for Water absorption |
The flexural strength data of the composites varied from 50,86 to 73,08 MPa.Based on the hypothesis test, the flexural strength was significantly affected by the addition of silicon carbide particles, exhibiting a rate of growingof 43,7%. Fig. 5 shows the increase in flexural strength.
| Figure 5. Graphic for Flexural Strength |
The idea behind the increase is due the high silicon carbide particles density, then the particles were decanted (fig. 3) under glass fibre, then, according some arguments shown by[9] in his review, a fibre surface coating occurred. The particles promoted an increased in the roughening the fiber–matrix interface affecting the bonding strength between both, causing an increase in the shear stress transfer at the interface, collaborate to increase the flexural strength[9].
| Figure 6. Increase of Modulus of Elasticity |
| Figure 7. SEM - Agglomerates of silicon carbide particles in the inferior region of polymer |
The modulus of elasticity varied from 6.65 to 6.63 GPa. The mean and standard deviation for each condition are shown in Table 1. Based on the Table 2, the two means are statistically the same (Table 2).For this reason, it is concluded the particle addition did not affect this response. Fig. 6 shows the increase in modulus of elasticity.The modulus did not affected by poor dispersion the particles into de epoxy matrix. Regions without particles in matrix phase can be observed (fig. 7). For improve the modulus, a good dipersion of particles, should be promoted.
4. Conclusions
The addition of micron silicon carbide particles provided the increase of apparent density and the reduction of water absorption of the composites. The addition of particles increased the flexural strength; however the modulus of elasticity was not significantly affected.
