Zenith "no hinge ailerons"
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by cheapracer, Nov 12, 2019.
  1. Nov 13, 2019 #21
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,568
    3,407
    Mojave, Ca
    Concerning piano hinges on a long, flexible wing - the Lockheed U-2 has piano hinges for both flaps and ailerons. The hinges themselves are standard MS extrusions with each lobe relieved a touch. The U-2 is not known for sporty handling, but the hinges survive just fine.
    As a tangent to this, the upper plennum lid on the Rocket is secured to the baffles with a continuous run of piano hinges. Thought I was real clever until I found a broken lobe caused by independent movement/expansion of the cylinders. Remembering the Lockheed solution, I spent a couple hours relieving each lobe with a file. Seems to be the solution here as well
    delta and flyboy2160 like this.
  2. Nov 14, 2019 #22
    Himat
    Himat
    Himat
    May 5, 2011
    2,858
    668
    Norway
    Many composite radio control sailplanes are made with the skin as a hinge. Do work and work at high speed. Have anybody here seen one of the DS Kinetic designs? The web pictures look like live hinges on them and a 130 Kinetic DP model was flown faster than 500mph.
  3. Nov 17, 2019 #23
    7,350
    2,117
    I looked into living hinges for my project but decided against them. The infinite life living hinges need a different type of PP than that used for Coroplast. They also do not like shear loads. My surfaces will have some flex, which would have a strong centreing effect with piano hinges and would put compressive and tensile loads on living hinges due to that. I have instead come up with non-binding mechanical hinges.
    It could be that living hinges could be made to work reliably and safely, but it's complex problem needing a lot more work than I'm willing to put in. The partial failure scenario also scares me.
  4. Nov 17, 2019 #24
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,550
    320
    Sydney
    Seems a problem in service life that should not get past the design board.
    Unless this hinge method is the only possibility for a point design- I would pass.
    Just use gaps seals if you must.
    From a buyers prospective- I would be wary and extremely so as a second hand buyer. I could see its value drop purely from doubts of buyers.
    Anything that screams experimental, unusual practice or short life span should be avoided.
    Not personally a fan of Zenith products either but that is a side issue.
  5. Nov 17, 2019 #25
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,831
    4,299
    Australian
    It's the 'simple' factor I was looking at, if it's a real problem in service life I don't know, was it the root cause of the CH601 crashes?
    I note the CH650 design is slightly different to the CH601 in that it appears to have greater length to flex with.
    Plenty of Zeniths out there with lots of hours, the high wings seem robust, but Zeniths seem to be built on the borderline of minimal material though, but because of that, the designs are good for research.
  6. Nov 17, 2019 #26
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,550
    320
    Sydney
    As a Aussie,
    The idea of a film hinge is scary even more than alloy.
    Some of our wildlife love attacking slow aircraft and even have ago at tearing your skins. Hate to have a moody Eagle make a tear in the hinge as it has its revenge.
    I know it sounds strange but.............were are a weird mob.
    And a Wedge tail is a very big Eagle. 1/3 rd bigger than Bald Eagle.
    Note damage to skin at end. I have seen vids of this same bugger- called "Jack the Ripper" attack a the same Goat glider, land on the leading edge and start pulling apart the skin in flight.
    Jack does not share his airspace. Either your a meal or a threat.
    Aerowerx likes this.
  7. Nov 17, 2019 #27
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,831
    4,299
    Australian
    Grammar, "a" does not come before a vowel in a sentence, so the start of your first sentence should read:
    'As a bloody Aussie Mate ...'
    akwrencher, Mad MAC and bmcj like this.
  8. Nov 17, 2019 #28
    13,175
    5,083
    Aaah, that’s just his mating ritual. Either that, or he saw the bigger Eagle with a tender human morsel in its mouth and it just wanted a piece of you for himself.
    Aerowerx and cheapracer like this.
  9. Nov 17, 2019 #29
    13,175
    5,083
    I would never consider using a living hinge, because a living hinge would eventually start thinking for itself and the next thing you know, it’s going to start demanding things like equal rights, union coffee breaks, etc.
    mcrae0104, BJC and akwrencher like this.
  10. Nov 17, 2019 #30
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,831
    4,299
    Australian
    I believe your term "living" hinge to be offensive to dead, non-operational, and discarded hinges, please try to find a more gender neutral term thank you.
    bmcj and akwrencher like this.
  11. Nov 17, 2019 #31
    anvegger
    anvegger
    anvegger
    Jul 6, 2015
    481
    124
    LACONIA NH USA
    Interestingly the CH approach is well defined
    [​IMG]
    And no problem have been detected with that hingeless design for years. Problems became noticeable when people started asking for hinge based ailerons. The hingeless aileron design have been known in European design way before the WWII - from 30-s if not 20-s. Many Soviet airplane designers have used that approach.
  12. Nov 17, 2019 #32
    anvegger
    anvegger
    anvegger
    Jul 6, 2015
    481
    124
    LACONIA NH USA
    Here is the example of fiberglass hingeless wing design of the sailplane
  13. Nov 17, 2019 #33
    anvegger
    anvegger
    anvegger
    Jul 6, 2015
    481
    124
    LACONIA NH USA
    It looks very much like Chris' solution
  14. Nov 17, 2019 #34
    Kyle Boatright
    Kyle Boatright
    Kyle Boatright
    Nov 12, 2012
    867
    494
    Marietta, GA
    Would that create a stress concentration between each pin segment? Would it matter?
  15. Nov 17, 2019 #35
    anvegger
    anvegger
    anvegger
    Jul 6, 2015
    481
    124
    LACONIA NH USA
  16. Nov 17, 2019 #36
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,831
    4,299
    Australian
    Technically, probably, but the stress is so low on a piano hinge that it wouldn't matter. That's a full aileron width piano hinge of course..
    The EAA recommend using 3 x 6" lengths of piano hinge if you think full width binding will be an issue.
  17. Nov 17, 2019 #37
    4,406
    2,069
    Just to clarify:. It wasn't the Zenith 601 that had all the problems. It was the Zenith 601XL. The wings are different between the two designs. The 601 has had a long history of safe flying, and it does use the hingeless ailerons (though many owners fit hinges). I would prefer hinges. Good control feel is an important attribute in a fun-to-fly plane, and these ailerons detract from it. If I were building a utilitarian little cargo hauler and wanted simplicity of build above all else, I could see the attraction.
    The Zenith/Zenair model names are not as clear as they could be, (IMO)
    Pops likes this.
  18. Nov 17, 2019 #38
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    393
    100
    Lt
    wsimpso1 likes this.
  19. Nov 17, 2019 #39
    12,660
    2,587
    What is the problem? Fatigue life 120,000 hours (post 31).
    By the way, cutting piano hinges to 6" segments won't prevent binding if the wing bends up in flight. In that case the aileron must be segmented like a Schweizer 2-33.
  20. Nov 17, 2019 #40
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,831
    4,299
    Australian
    I think it's the mindset I referred to earlier, who hasn't flex a material back and forward a few times and had it fail.
    Boku has a solid point though, the 'hinge' can move in a vertical plane, a hinge certainly can't.
    During flutter it must be a crazy scene with that extra axis of movement.
