Taiser
Once the skeleton is final drilled and riveted together then the bottom skin and nose skin gets fitted...
Skins clecoed together...
Then the nose skin gets pulled back with the straps and once you verify everything is snug you drill through the holes in the skin into the spar. This part is an absolute NIGHTMARE to do!!
Top skin is on, now everything gets final drilled to their proper size...then it all comes apart!
