XFLR5 update
Aerowerx
Dec 1, 2011
5,371
Marion, Ohio
Cm...what about it ?
IIRC the negative Cm means that it will pitch up into a stall. Which means a H-tail is needed to counteract the Cm of the wing.
You already have a very high AoA of 18 degrees. With out seeing the polar plots it is hard to say what it is doing.
ScaleBirdsPaul
Jul 6, 2015
37
Connecticut
Normal convention is negative Cm is a nose down moment. At 18+ degrees AoA I’m guessing he’s well past the linear increase in Cl and XFLR is throwing out weird results.
Speedboat100
Nov 8, 2018
961
Europe
Yes here are 0-12 degs AOA polars.
Jul 29, 2005
14,013
Inviscid results aren't terribly accurate. Calculate a Reynolds number and Mach number and run a polar for those conditions.
Aerowerx
Dec 1, 2011
5,371
Marion, Ohio
Your polars show the max CL of about 1.45 at AoA of 10 degrees. I wouldn't trust anything beyond that.
And as Topaz said, inviscid isn't that good.
Remember this is a mathematical simulation of reality. The results are only reasonable* within the linear, not turbulent regions.
*insert your own definition of reasonable here.
ScaleBirdsPaul
Jul 6, 2015
37
Connecticut
Looks like there’s an update on a new version of XFLR5 called flow5. Looks to be much more powerful but will be a paid software.
https://flow5.tech/
There’s a series of YouTube videos that I’m working through to see if it seems worth the price.
Aerowerx
Dec 1, 2011
5,371
Marion, Ohio
https://flow5.tech/
Not really a version of XFLR5.
There are several related programs, all from the same developer. My conjecture is that they used the same basic algorithms to solve the fluid dynamics, but each is tailored for different purposes.
