Work rules / practices
FinnFlyer
Nov 19, 2019
39
Bell, FL
OK, so it's not called for in the plans and is just an optional procedure. Really needed? Depends on the amount of engine vibration and interaction between cowling and engine.
Finn
rv7charlie
Nov 17, 2014
1,367
Jackson
Guys, I'm not building an RV, and my plans / instructions do not indicate the holes you have recommended.
I'm not disagreeing with what you are saying wrt the RV, only that my installation is different.
"Failure to communicate."
Finn said that it's definitely in the RVx plans; you responded that it's not in 'the plans'. I responded with a quote from the RVx build manual. Then you clarified that it's not in *your* plans.
I don't know what you're building, but assumed that it might be a scratch-build or something with little detail in the plans, since builders of the more common kits that use hinge stock on the cowl don't have issues with distorting the cowl when installing the hinge stock, as long as it's formed correctly and held in place properly while drilling. Simply squeezing the rivets won't stretch the hinge stock enough to affect alignment.
Charlie
12,697
Sorry for the confusion.
There is a photo of the Glasair that I am slowly building in post #146. The Glasair uses piano hinge to attach the vertical, almost straight, portion of the lower cowl to the fuselage, and to tie the horizontal joint between the upper and lower cowl sections together. The plans call for Dzus fasteners for the bottom and top of the cowl to fuselage attachments. My question related to the top of the cowling to fuselage attachment where, contrary to the plans, I am using hinge.
Rivets squeezed and rivet heads covered with one layer of glass. It did not have any noticeable distortion.
Thanks to all who commented.
12,697
My pet peeve is a zillion zip ties. I’m a lace cord kinda guy.
A friend / former co-worker taught basic wiring techniques at SnF for many years. He could apply lace cord faster than most could apply ties, and his looked much better.
14,345
The beauty of hinge to hold the cowl on is when lining up to run the wire through, and it’s slightly miss aligned, getting the wire through your finger is easy. It lines up perfectly to skewer.
7,780
I dare anyone to claim to have too many Clecoes.
LOL.
I am building a fiberglass airplane (uses between on and two orders of magnitude less Clecos than an aluminum bird) and I believe I have few extra 3/32 and 1/8. I am not giving any away because I know the day will come when I wish I had them all and maybe a few more....
12,697
I visited a multi-HBA builder, and prominently on his table was a vacuum sealer. His standard practice is to vacuum pack all hardware that he doesn’t need for his current task, to protect it from humidity driven rust / corrosion. I doubt that Toobuilder would benefit from this practice, but it is helpful here in high-humidity Florida, unless one runs a dehumidifier.
Does anyone here similarly vacuum seal hardware?
8,912
Yes, on building the 4 Bearhawks, we built all 4 parts at the same time and Vac-bagged all the small fitting, etc. Also cut all the fuselage tubes just a little long and marked where they went for all the builds. Saves a lot of time.
  • Like
Reactions: BJC
don january
Feb 10, 2015
3,031
Midwest
Not sure if mentioned but I found a good throw rug to stand on makes long term sanding or even gluing much easier on the back and legs. I'm not so fancy with a vac baggier but good old sandwich bags marked with a permanent marker has help me from to much search time
12,697
Agree. That is a big issue for me. I buy some of these https://www.northerntool.com/shop/tools/product_200699633_200699633?cm_mmc=Google-LIA&utm_source=Google_LIA&utm_medium=Safety > Safety Matting&utm_campaign=Ironton&utm_content=60769&gclid=EAIaIQobChMIxf7prsHx7AIVBoiGCh2ljwuwEAQYASABEgKWrvD_BwE&gclsrc=aw.ds
when they are on sale, and they make a big difference verses a concrete floor.
don january
Feb 10, 2015
3,031
Midwest
Yep Hot Wings. I have trouble seeing on top of the refrigerator so shelves in my build area is for a place the wife can hide things from me in fact I've turned around to grab my beer and yep the better half has placed it up yonder to mess with my head.
